SecurityAssist Login
My login page seems to be hardcoded to one page.
$WA_redirectURL = "Docs_Search.php";
How can I change this to use the page that user came from?
Such as AccountWeb_detail.php?CustomerID=7F4556001
in the security assist login behavior, there is an options to Go to the Previous URL if it exists, it looks for an accesscehck url variable to determine the previous page.
make sure that option is enabled in the login behavior, and also make sure the login form action is set to forward any URL variables that are passed into it:
action="<?php echo htmlspecialchars($_SERVER["PHP_SELF"]); ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".htmlspecialchars($_SERVER["QUERY_STRING"]):""; ?>"
How do I get back into the security assist login behaviors?
on the login page, open the server behaviors panel, they security assist authenticate user server behaviors for the login page will be in the server behaviors list, double click them to edit.
I had to reinstall Databridge. When I click on the behavior it removes all the data.
How do I get the system to recognize that it is valid. The system is in production...I cannot start over.
send a link to your page and FTP information, and i can make the change for you.
include a test logon as well please.
on your login page, the forms action was not updated to pass the existing query string.
i changed the action to use the code suggested in my first reply
you didn't provide a test login, so i can't test this, but i believe it should fixture issue.
