add content doesn't work
Thread began 1/29/2015 10:21 am by City of Port St Lucie | Last modified 1/29/2015 10:42 am by Jason Byrnes | 573 views | 1 replies |
I just installed Design Extender. I am using Dreamweaver CC. I am trying to add content but when I click the menu item ti add content, nothing happens. I tried dragging and dropping the powercms content item from the webassist toolbar in INsert tab but I get a javascript error. What am I missing? The install and setup instructions arent very helpful. Can someone help me? Thx
Sounds like the WebAssist installer did not run.
After installing the WebAssist extensions in the DW Extension manager, when you open DW, it should launch the WebAssist installer. if the WebAssist installer does not open automatically, open a php page to force it to start. After the WebAssist installer completes, make sure to restart DW.
you will also need to install the Deprecated server behaviors extension availbale from Adobe:
http://www.webassist.com/tutorials/Deprecated-Server-Behaviors-for-Dreamweaver-Creative-Cloud
Also, make sure you have your site defined for dynamic development, see the following tutorial:
http://www.webassist.com/tutorials/Define-a-dynamic-site-in-CS5
and that you have a database connection set up:
http://www.webassist.com/tutorials/Create-a-PHP-database-connection
Note that you can only add CMS content to a php page, If you are working on a static html page, it wont be able to work.
if you continue to have problems, please include the text of the error message.
