not sure what search terms I should be using
Thread began 1/28/2015 8:37 am by Jamie | Last modified 1/29/2015 9:36 am by Jason Byrnes | 1018 views | 3 replies |
Jamie
Hi Jason
I am looking to recreate the sort of postcode based search found on this page http://bit.ly/18uHOXP or this one http://bit.ly/1uBecfV (on the property search bit on left hand column) but am struggling with searching to find resources...not sure what sort of search term I should be looking with. Just wondering if you might have a pointer or two that I could use as a jumping off point?
Cheers
Jamie
so your trying to do a zip code radius search.
search google for
php post code radius search
or
php postcode radius search
heer is one result i found that should be helpful:
http://stackoverflow.com/questions/2410529/php-mysql-zip-code-proximity-search
Jamie
thanks mate, appreciate the pointer and will investigate
Jamie
you're welcome.
