I am having problems witjh my contact page
Thread began 1/25/2015 1:42 pm by bbgd | Last modified 2/03/2015 12:43 pm by Jason Byrnes | 1613 views | 13 replies |
bbgd
This page was working perfect and then I get a message that there are errors. I did a test and sure enough, these showed up. The link to the page is http://test2.interprimus.com/contactPage.php. Please advise what went wrong.
Notice: Undefined index: ckbx_email in /home/cinder2bob/public_html/test2/contactPage.php on line 34
Notice: Array to string conversion in /home/cinder2bob/public_html/test2/ScriptLibrary/incSmartMailer.php on line 274
Strict Standards: Non-static method smtp::connect() should not be called statically, assuming $this from incompatible context in /home/cinder2bob/public_html/test2/ScriptLibrary/htmlMimeMail.php on line 713
Strict Standards: Only variables should be assigned by reference in /home/cinder2bob/public_html/test2/ScriptLibrary/htmlMimeMail.php on line 713
Strict Standards: Non-static method Mail_RFC822::parseAddressList() should not be called statically, assuming $this from incompatible context in /home/cinder2bob/public_html/test2/ScriptLibrary/htmlMimeMail.php on line 717
Strict Standards: Non-static method Mail_RFC822::parseAddressList() should not be called statically, assuming $this from incompatible context in /home/cinder2bob/public_html/test2/ScriptLibrary/htmlMimeMail.php on line 729
Strict Standards: Non-static method Mail_RFC822::parseAddressList() should not be called statically, assuming $this from incompatible context in /home/cinder2bob/public_html/test2/ScriptLibrary/htmlMimeMail.php on line 751
Error sending e-mail
AUTH command failed: Incorrect authentication data
Please correct and try again
you seam to be using a mail script that is not ours:
the first error suggests that code at line 34 is looking for a post element named ckbx_email that does not exist in the form.
the other errors suggest that there are errors in the mail script, but it doesn't look like you are using the WebAssist Universal Email, so I can't really troubleshoot to much.
bbgd
I'm shocked. I will re-do the page with Universal Email. Thanks and sorry to bother you. Of course, I'll be back.
the connections file not being uploaded is not that big a deal,
bbgd
Thanks. http://test2.interprimus.com/contactPage_webassist.php.
you had set the forms action to post to the WU Settings page in the web assist/email folder. the action needed to be set to pot the page the form is on.
i also need to change the from address.
you had set it to use the email address element in the form, most hosts require the from address to be a valid email for your domain, otherwise they treat it as spam.
i edited the from address to:
$MailFrom = "info@interprimus.com";
i add my email in the to section and was able to receive the message once i changed the from address and the forms action.
bbgd
I just received it also. What files do I have to download to my computer to have all the changes you made other than contactPage_webassist.php. Oh, thanks you very much.
the only files i edited are:
webassist/email/waue_contactPage_webassist_1.php
on the contactPage_webassist.php page, i changed the form action.
on the webassist/email/waue_contactPage_webassist_1.php page i edited the from address.
bbgd
Thank you very much
you're welcome.
