ERROR:database does not exist. Please verify the database exists and the MySQL user (***************) has the correct privileges to access it.
Thread began 1/16/2015 6:04 am by mike-j-taylor318947 | Last modified 1/22/2015 1:19 pm by Jason Byrnes | 333 views | 3 replies |
mike-j-taylor318947
This post has been deleted.
If the database does exist, then the error suggests that the user you are using to access it, does not have proper privileges to be able to access it.
you should contact your host to have them help you investigate the registered database users and elevate the privileges for the user you are trying to connect with.
mike-j-taylor318947
Its all sorted now, it was a problem with the server configuration
you're welcome.
