Binding recordsets to a selected item in a dynamic dropdown list
Thread began 1/15/2015 6:30 pm by MR JOHN | Last modified 1/16/2015 11:58 am by Jason Byrnes | 1828 views | 3 replies |
MR JOHN
HI I've created a dynamic dropdown list using a record set of event names, this give me a dropdown list. I need to be able to use this dropdown selection to show details from the selected linked record item. So for example a list of cars, i select the car from teh drop down list and my other field items, type, notes etc are updated based on my dropdown record.
I'm stuck on how i go about doing this, I have databridge and using mysqli with DW 2014.1
Please give step by step instructions
the value for the list should use the event ID column. make sure the select list form is set to use the post method, and it should have a submit button
make note of the select list name.
on the details page, create a recordset to return the requested event. in the recordset filtering section, set the filtering to use the EventID column Equal to Form value, and enter the name of the select list.
you may find the database starter kit tutorial helpful:
http://www.webassist.com/tutorials/Getting-started-with-MySQL-and-dynamic-websites
MR JOHN
Hi, what I need is for the record set to be linked to me clicking the selected list item from a dropdown list. Not clicking a submit button so when I select the item in the drop down (not the record I'd) this will cause an update of the recordset and thus displaying the record info.
I'd the dropdown is not the is of the database record but a human readable data field
How do I achieve this please. Can I do this via an onchange event to post the id to update the recordset
this would require unsupported hand coding.
you could add an onchange event to the select list to submit the form. see this post at stack overflow:
http://stackoverflow.com/questions/7231157/how-to-submit-form-on-change-of-dropdown-list
