Correct Use of Framework Plugin
Hello Jason,
I want to make more use of the framework builder in order to update some old websites. I have some general questions relating to the correct process of applying the framework builder as a plugin and theme. I have been experimenting with it for a week but would like some clarity on aspects that I cannot find in its documentation.
Four Quick questions.
[Q1] Should all server behavior requirement be performed on say a contact page prior to its application as a framework plugin or should that happen on the page hosting the contact page plugin?
[Q2] Should Recordset be generated as normal on a page that would be used as a plugin, or should the recordset be generated on the page hosting the plugin?
[Q3] Should the contact page plugin be styled using CSS as any normal page and then included in the plugin with link to the CSS in the <head> or should the link to the CSS be removed after styling and added to the page hosting the contact page plugin?
[Q4] When contact page or say even SecurityAssist generated login, registration, userupdate, forgottenpassword pages are used as plugins, does that change the form action=""? What will be the form action for contact page for example?
Thanks in advance!
