mysql extension is deprecated and will be removed in the future
Thread began 12/11/2014 6:45 am by gary.brett434358 | Last modified 12/11/2014 12:56 pm by Jason Byrnes | 363 views | 1 replies |
gary.brett434358
Good morning, I have a range of suites from WebAssist that I built a CRM with 2 years ago. Recently I updated my WAMP which has upgraded both PHP & Mysql, now whenever I attempt to use the DataAssist inside Dreamweaver CS4 it throws errors like 'mysql extension is deprecated and will be removed in the future'.
If I edit the connection string to msqli it connects but then throws all sorts of other errors, I am guessing as the output code is mysql and not msqli.
Is there any way around this as I am now stuck on any further development with this CRM, even though the actual site itself works fine on live hosting?
I notice my suites have been superseded with Databridge, would this output the msqli code that will be safe going forward?
Many thanks
Gary
in the php.ini file, edit the error reporting level to turn off deprecated warnings:
error_reporting = E_ALL & ~E_DEPRECATED
we are working on an upgrade to Data Bridge to use MySQLi, we are targeting the first quarter of 2015 for it's release.
