Text / Drop-down Menu Combo Field
Thread began 12/09/2014 10:08 am by DeanCollins | Last modified 12/09/2014 11:13 am by DeanCollins | 700 views | 2 replies |
DeanCollins
Sorry if this has been asked and answered.
Is it possible with WebAssist tools to create a field into which I can either type a value (and have it saved to a database table) or select an existing item from a drop-down menu?
For example, in "DataAssist: Create Pages," when saving, you can either type in a new "schema" or select from the list of existing schemas.
No, Data Bridge does not have native support for a data list like you describe, you would need to hand code this. you should be able to find examples through google. here is one example i found:
http://jsfiddle.net/joshpauljohnson/Uv5Wk/
DeanCollins
Thanks!
