Warning: require_once(webassist/ecart/checkout/credentials/gateways.php)
Thread began 12/07/2014 10:08 pm by simmo515303621 | Last modified 12/11/2014 12:40 pm by Jason Byrnes | 456 views | 3 replies |
simmo515303621
Hi I have tried to use the new eCart, I am also using MySQLi. and dreamweaver CC
For this particular job i am only creating a quoting system and dont need the gateway. I choose no payment gateway, but the checkout page is still looking for the above file. This file is not added to the folder structure by default when choosing none for gateway thus giving you this error.
If I go ahead and uredo and choose a gateway it will over write the existing files and also add the gateways.php, then I can go back and do it again and choose no gate way and we get no error.
However on the confirm.php page is giving this php error. Fatal error: Class 'WA_MySQLi_Query' not found in C:\wamp\www\popup\confirm.php on line 24.
this is line 24. $ConditionalQuery = new WA_MySQLi_Query($SAVVY);
The following are available on the page, as i thought that perhaps the db connection was missing, but it is there.
<?php require_once('webassist/mysqli/queryobj.php'); ?>
<?php require_once('Connections/SAVVY.php'); ?>
Any idea's?
make sure that these lines:
come before line 24.
if you continue to have a problem, please send a copy of the page.
simmo515303621
Hi Jason,
Ok this is one of those "Honestly it wasn't working, and now it is!" problems. Seems to be ok now.
ok, glad to hear it is working.
