Don´t save the correct value.
Hi all seems to work fine when you run the page. But when value is saved on database from clild field it saves the id_value instead of the value displayed on page...
<?php require_once('../Connections/bichos.php'); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$editFormAction = $_SERVER['PHP_SELF'];
if (isset($_SERVER['QUERY_STRING'])) {
$editFormAction .= "?" . htmlentities($_SERVER['QUERY_STRING']);
if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "insert")) {
$insertSQL = sprintf("INSERT INTO eventos_complementos (id_evento, id_complemento, precio) VALUES (%s, %s, %s)",
GetSQLValueString($_POST['Child'], "text"),
GetSQLValueString($_POST['Child'], "text"));
mysql_select_db($database_bichos, $bichos);
$Result1 = mysql_query($insertSQL, $bichos) or die(mysql_error());
$query_Parent = "SELECT * FROM platillos_especiales";
$Parent = mysql_query($query_Parent, $bichos) or die(mysql_error());
$row_Parent = mysql_fetch_assoc($Parent);
$totalRows_Parent = mysql_num_rows($Parent);
$query_Child = "SELECT * FROM platillos_especiales";
$Child = mysql_query($query_Child, $bichos) or die(mysql_error());
$row_Child = mysql_fetch_assoc($Child);
$totalRows_Child = mysql_num_rows($Child);
function WA_DD_Replace($startStr) {
$startStr = str_replace("'", "|WA|", $startStr);
$startStr = str_replace("\\", "\\\\", $startStr);
$startStr = preg_replace("/[\r\n]{1,}/", " ", $startStr);
return $startStr;
<!doctype html>
<html>
<head>
<meta charset="UTF-8">
if ($row_Child) {
echo "<SC" . "RIPT>\n";
echo "var WAJA = new Array();\n";
$oldmainid = 0;
$newmainid = $row_Child["id_platillo"];
if ($oldmainid == $newmainid) {
$oldmainid = "";
$n = 0;
while ($row_Child) {
if ($oldmainid != $newmainid) {
echo "WAJA[".$n."] = new Array();\n";
echo "WAJA[".$n."][0] = '".WA_DD_Replace($newmainid)."';\n";
$m = 1;
echo "WAJA[".$n."][".$m."] = new Array();\n";
echo "WAJA[".$n."][".$m."][0] = "."'".WA_DD_Replace($row_Child["id_platillo"])."'".";\n";
echo "WAJA[".$n."][".$m."][1] = "."'".WA_DD_Replace($row_Child["precio"])."'".";\n";
$m++;
if ($oldmainid == 0) {
$oldmainid = $newmainid;
if ($row_Child) {
$n++;
echo "var Child_WAJA = WAJA;\n";
echo "WAJA = null;\n";
echo "</SC" . "RIPT>\n";
function WA_ClientSideReplace(theval,findvar,repvar) {
var retval = "";
while (theval.indexOf(findvar) >= 0) {
retval += theval.substring(0,theval.indexOf(findvar));
retval += repvar;
theval = theval.substring(theval.indexOf(findvar) + String(findvar).length);
retval += theval;
if (retval == "" && theval.indexOf(findvar) < 0) {
retval = theval;
return retval;
function MM_findObj(n, d) { //v4.01
var p,i,x; if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n];
for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document);
if(!x && d.getElementById) x=d.getElementById(n); return x;
function WA_UnloadList(thelist,leavevals,bottomnum) {
while (thelist.options.length > leavevals+bottomnum) {
if (thelist.options[leavevals]) {
thelist.options[leavevals] = null;
return leavevals;
function WA_FilterAndPopulateSubList(thearray,sourceselect,targetselect,leaveval,bottomleave,usesource,delimiter) {
if (bottomleave > 0) {
leaveArray = new Array(bottomleave);
if (targetselect.options.length >= bottomleave) {
for (var m=0; m<bottomleave; m++) {
leavetext = targetselect.options[(targetselect.options.length - bottomleave + m)].text;
leavevalue = targetselect.options[(targetselect.options.length - bottomleave + m)].value;
leaveArray[m] = new Array(leavevalue,leavetext);
else {
leavetext = "";
leavevalue = "";
startid = WA_UnloadList(targetselect,leaveval,0);
mainids = new Array();
if (usesource) maintext = new Array();
for (var j=0; j<sourceselect.options.length; j++) {
if (sourceselect.options[j].selected) {
mainids[mainids.length] = sourceselect.options[j].value;
if (usesource) maintext[maintext.length] = sourceselect.options[j].text + delimiter;
for (var i=0; i<thearray.length; i++) {
goodid = false;
for (var h=0; h<mainids.length; h++) {
if (thearray[i][0] == mainids[h]) {
goodid = true;
break;
if (goodid) {
theBox = targetselect;
theLength = parseInt(theBox.options.length);
theServices = thearray[i].length + startid;
var l=1;
for (var k=startid; k<theServices; k++) {
if (l == thearray[i].length) break;
theBox.options[k] = new Option();
theBox.options[k].value = thearray[i][l][0];
if (usesource) theBox.options[k].text = maintext[h] + WA_ClientSideReplace(thearray[i][l][1],"|WA|","'");
else theBox.options[k].text = WA_ClientSideReplace(thearray[i][l][1],"|WA|","'");
l++;
startid = k;
for (var n=0; n<leaveArray.length; n++) {
targetselect.options[startid+n] = new Option();
targetselect.options[startid+n].value = leaveArray[n][0];
targetselect.options[startid+n].text = leaveArray[n][1];
for (var l=0; l < targetselect.options.length; l++) {
targetselect.options[l].selected = false;
if (targetselect.options.length > 0) {
targetselect.options[0].selected = true;
</script>
</head>
<body>
<form method="POST" action="<?php echo $editFormAction; ?>" name="insert" id="insert">
<select name="Parent" size="10" id="Parent" onChange="WA_FilterAndPopulateSubList(Child_WAJA,MM_findObj('Parent'),MM_findObj('Child'),0,0,false,': ')">
do {
<option value="<?php echo $row_Parent['id_platillo']?>"><?php echo $row_Parent['nombre_platillo']?></option>
} while ($row_Parent = mysql_fetch_assoc($Parent));
$rows = mysql_num_rows($Parent);
if($rows > 0) {
mysql_data_seek($Parent, 0);
</select>
<select name="Child" id="Child"></select>
<input name="Add" type="submit" id="Add" value="Add to list">
<input type="hidden" name="MM_insert" value="insert">
</form>
</body>
</html>
mysql_free_result($Parent);
mysql_free_result($Child);
