upload not working
Thread began 12/03/2014 2:52 pm by Sweens | Last modified 12/03/2014 4:06 pm by Jason Byrnes | 249 views | 3 replies |
Sweens
upload not working
Hi Jason
Having real problems with the attached page. On the second form, the image upload doesn't work - but a new record is created and inserted properly.
I've changed he form to use multipart/form data and that hasn't made any difference.
Previously I was getting the 'headers already sent' message, but when I removed the redirect url, the error went - I don't know if this is relevant or not (I couldn't fin any extra spaces that might be causing he headers sent message)
Hope you can throw some light on this
Thanks, as ever
Chris
the form tag for the form that has the file field is at line 255:
<form action= "" method="post" name="fmAddQL" id="fmAddQL">
this form tag does not have the encoding type set to multipart/form-data. is should be:
<form action= "" method="post" enctype="multipart/form-data" name="fmAddQL" id="fmAddQL">
for the upload to work, the encoding type must be set.
if it is still not working after changing the upload type, leave the redirect off, and go to the bindings panel, expand the WA Uploaded Files Global Status group and add the debug info binding to the page, also, add the following code to write the files collection, and post results back:
<?php var_dump($_FILES); ?>
NOTE: both of those should be in the page body.
Sweens
Hi Jason
I could have sworn I'd done that! It now works.
Sorry to waste your time - and thanks.
Cheers
Chris
no worries.
