Different $_SESSION variable set in checkout
Thread began 12/03/2014 12:12 pm by troyd | Last modified 12/03/2014 6:51 pm by Jason Byrnes | 514 views | 6 replies |
troyd
This could easily be something that I inadvertently did when recreating the checkout through the wizard.
For some reason, a session $_SESSION["WASF_CheckoutWizard_Compact_Default"] is created and holding all of the checkout information. However, all of rules and checkout form use CheckoutWizard_NewFromBlank_Default. It caused sales tax not to work but fixed that by changing the rule in the eCart1_PHP.php page but it seems odd that the session CheckoutWizard_NewFromBlank_Default isn't the one being set by the form's post instead.
I made sure this is at the top of the confirm_cart.php page.
@session_start();
if (isset($_POST["CheckoutWizard_submit"]) || isset($_POST["CheckoutWizard_submit_x"])) {
WA_persistForm("session","CheckoutWizard_NewFromBlank_Default",0,"/","");
I think that one of the times I recreated the checkout through the wizard, I selected the "Compact" address form by mistake. But I've done a thorough search for the word CheckoutWizard_Compact_Default and even "_Compact_" and don't find a thing.
I see that the "WASF" is appended in the persist.php page but I don't see where the CheckoutWizard_Compact_Default session is even set.
I though maybe I had some caching issues or files where not being uploaded/overwritten correctly. I've cleared cache, deleted remote folders and re uploaded. Still the same problem. Any thoughts?
BTW. It's on my local server or I would have included a link to the page with the session dump. I can provide files but didn't know which one to start with.
Thanks,
TroyD
This will happen on rerunning the checkout wizard and using a different form style. Before rerunning the checkout wizard, you should edit the cart object and remove any shipping rules that the wizard created the first time around so they can be regenerated.
If you want me to look at the code, send the checkout, confirm, and confirm cart files.
troyd
Thanks Jason,
Yea, I fixed the shipping and tax rules by changing them to reflect the $_SESSION["WASF_CheckoutWizard_Compact_Default"]. But as you will see in my files, the other session is everywhere.
I can't find where the $_SESSION["WASF_CheckoutWizard_Compact_Default"] is set. Should everything be using the same session? Either "WASF_CheckoutWizard_Compact_Default" or "WASF_CheckoutWizard_NewFromBlank_Default" but not both?
Thanks,
TroyD
Did you maybe test the checkout with the original files, then delete them and create them again and test again with out closing the browser?
if you tested again without closing the browser, it would be remembering the session created from the original checkout pages.
I don't see where the WASF_CheckoutWizard_Compact_Default session is being created in the pages you attached.
I would need you to upload to the server in order to troubleshoot further.
troyd
No, I have scrubbed my browser's cache, history, cookies, etc. I even destroyed all sessions.
I always close my browser and even reboot if needed when dealing with these types of things. However I have noticed that Dreamweaver is not perfect about overwriting files and folders when "Putting" them. Sometimes I have to delete everything in question remotely and then upload. I will do that again and see. If not, I will move things to a live server and have you take a look.
Thanks,
TroyD
troyd
It turned out to be just that. I guess Dreamweaver would not overwrite the files when I uploaded them. I even deleted the files and the webassist folder and eCart folder from within Dreamweaver. That did not fix the problem.
In the end, what I did was delete the files and those two folders from outside of Dreamweaver then uploaded them again. That fixed it on the first try.
I'm not sure why Dreamweaver isn't actually replacing files when you "Put" them but it isn't for me. Not always. BTW. I'm using CS6.
Thanks for the help,
TroyD
Yeah, I trust DWs FTP as far as I can throw it. I prefer to use File Zilla to manage files on the site.
