Getting error message
Thread began 11/19/2014 2:53 pm by Terry | Last modified 11/20/2014 9:34 am by Jason Byrnes | 530 views | 1 replies |
Terry
First, I am getting the following message in a Dreamweaver box:
The document's current encoding can not correctly save all the the character within the document. You may want to change to UTF-8 or an encoding that supoorts the special characters in this document.
What I have done is as a follows: Modify-Page Properties-Title/Encoding-Encoding-Unicode (UTF-8)-Apply-Ok,but I a still getting the above message.
Second, I am getting the following message is a Dreamweaver box:
We tried to create your database table for you, but were unseccesful. The CREATE TABLE statement has beem stored in a sql file located at:
webassist/security_assist/optin2_users3.sql
This file can be used to create the table in your database. We are sorry for the inconvenience. Please contat WebAssist Support if this problem persist.
Question: Why am I getting this message. What can I do to allow webassist to create the database my itself.
The first error message means that there are some characters on your page that are not supported by the UTF8 encoding.
either you will need to use a encoding that supports those character, or remove them from the page.
As for creating the table, there are a number of things that may cause this. Most likely it is a problem with the testing server settings in your site definition.
the SQL script that is created can be used to import the table manually:
http://www.webassist.com/tutorials/Import-a-sql-file
