Upload and resize big images. Draemveaver CC
Thread began 11/18/2014 2:00 am by Venosites | Last modified 11/18/2014 12:18 pm by Jason Byrnes | 1035 views | 3 replies |
Venosites
I upload a big image 5,6MB, I don't make changes, there is no problem and the image wil uploaded, but if I make changes it fails on images bigger than 3MB, where do I need make changes to upload crop bigger images? in the phphelper?
How to install the extensions in dreamweaver 2014.1?
This is a server configuration issue.
When resizing an image, it takes up memory on the server, the larger the image, the more memory is needed.
The server will have a setting in the php.ini to set the maximum amount of memory a script can use, wit the larger images, it receding the allowed memory usage.
you may be able to increase the allowed memory by adding the following code at line 1 of your page:
ini_set("memory_limit", "256M")
if that does not work, you'll need to contact the host.
Venosites
Thanks, for the fast answer, it helps for me!
you're welcome.
