Is there a way to 'Add to Cart' from a link from an external website using a query string
Thread began 11/14/2014 1:08 pm by dDog | Last modified 11/14/2014 3:24 pm by Jason Byrnes | 250 views | 3 replies |
dDog
Hello,
We have an external website (non php) which we would like to allow to add unique products into the ecart shopping cart and check out. Is there a way to add products to the cart using a link to the cart.php page with a query string containing the ProductName, ProductSKU, ProductPrice and ProductQuantity. The products would not necessarily be in our products database.
you could dod this using the add to cart server behavior.
first make sure to create a binding for each URL variable, on the bindings panel, click the plus button, select URL variable, then add the name for the binding, rinse and repeat for each URL variable.
then go to the server behaviors tab and click the plus button, select eCart -> Add to Cart -> Add to cart.
for the cart columns, bind each one to the corresponding URL variable.
dDog
Thanks!
you're welcome.
