eCart: Edit email settings without using Checkout Wizard
Thread began 11/12/2014 2:11 pm by tmcbinc99963 | Last modified 11/12/2014 5:31 pm by tmcbinc99963 | 414 views | 8 replies |
tmcbinc99963
I need to edit the email 'send to' address in the Checkout Wizard. I've made several css adjustments outside of the Checkout Wizard, which will be lost if I recreate those pages. How can I make the edits without using Checkout Wizard?
open the confirm.php page (or pp_confirm.php page if using express checkout.
open the server behaviors panel, windows -> server behaviors, locate the universal email server behavior and double click it to edit the settings.
tmcbinc99963
Not using UE, only the eCart Checkout Wizard email settings. Not using express checkout either.
eCart 6 adds the UE server behavior for sending the email.
so open the confirm page, open the server behaviors panel, and double click the UE server behavior to edit it's settings.
tmcbinc99963
Not seeing the server behavior on confirm page. Attached is screen shot in png format.
Ok, you may need to edit the code directly then, send a copy of the confirm page.
what are you trying to change the To address too?
tmcbinc99963
PM
I don't see the email code on this page, perhaps it's on the checkout success page.
tmcbinc99963
Never mind. I decided to use the Authorize.net email.
