Recordset return multiple results
Thread began 11/11/2014 12:52 pm by tn228553 | Last modified 11/11/2014 2:34 pm by Jason Byrnes | 323 views | 5 replies |
tn228553
I have the following recordset that queries a MySQL database and works fine. The only problem is that it returns a single record and not all matching records where the WorkOrder variable matches the WorkOrder column in the database. I need to return all records instead of just the one into a text area. How do I achieve this? FYI, I am displaying the results of the RecordSet with an echo like this: <textarea name=\"Widget\" cols=\"\" rows=\"\">".$row_Plugins1['WidgetNote']."</textarea>
RecordSet Code:
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$colname_Plugins1 = "-1";
if (isset($_SESSION['WorkOrderNum'])) {
$colname_Plugins1 = $_SESSION['WorkOrderNum'];
$database_connection = db_name;
$connection= mysql_connect(host_name,db_user, db_pw);
mysql_select_db($database_connection, $connection);
$query_Plugins1 = sprintf("SELECT * FROM HTG_Widgets WHERE WorkOrder = %s", GetSQLValueString($colname_Plugins1, "text") ."LIMIT 10");
$Plugins1 = mysql_query($query_Plugins1, $connection) or die(mysql_error());
$row_Plugins1 = mysql_fetch_assoc($Plugins1);
$totalRows_Plugins1 = mysql_num_rows($Plugins1);
do you have a repeat region on the page around the echo? to display all results returned by the recordset, you need to use a repeat region.
tn228553
Sample Repeat Region
See private message.
select the area you want to repeat, then go to the server behaviors panel and click the plus button, select repeat region.
In the database starter kit, I go through using the repeat region:
http://www.webassist.com/tutorials/Getting-started-with-MySQL-and-dynamic-websites
tn228553
Got it, thanks!
you're welcome.
