Image resizer
Thread began 11/11/2014 9:34 am by russb335115 | Last modified 11/11/2014 11:18 am by Jason Byrnes | 1524 views | 9 replies |
russb335115
Image resizer
I'm getting an error on my results page when I applied the image resized. Here is the error:
/homepages/19/d403739231/htdocs/antronix/webassist/caching/CachedResize_Image.php on line 283
Here is the page:
http://s403739248.onlinehome.us/antronix/antronix-Products-Drop-Passives-Splitters.php
When I use the filter to get results the error above shows just above the image and the images aren't resizing
the error:
  Strict Standards: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/New_York' for 'EST/-5.0/no DST'
This is a php server issue.
The host should be able to update the php.ini file for you to set the default timezone to prevent that error from occurring. It happens if the default time zone is not set in the php.ini.
alternativly, you can add the following at line 1 of the results page:
date_default_timezone_set('America/New_York');
but it is best to set the default time zone in the php.ini file so you won't have to keep setting it in other files.
The list of valid timezones is here...
http://www.php.net/manual/en/timezones.php
russb335115
Awesome that got ride of the error but it seems like the image resized isn't working.
looks like it is working to me. if i view the image source, the path is:
image_cache/images/products/fit/CMC2002LC-A_w200_h181/CMC2002LC-A_09021119.jpg
that is the path to the resized image.
russb335115
See PM
they both look the same size to me.
russb335115
I think I'm not explaining it correctly. So the image is in a image holder which is what the image resized is attached to. the image holder is part of a repeat region (from the results page) but the second image holder is larger that the first when they should be the same. Plus the second image lost the formation which has a 10px right margin.
your image tag does not specify the width or height attributes.
image resizer determines the width and eight for the resized image based on the width and heigh attributes set in the image tag.
with no width or height, it does not know what size to recreate the images at.
russb335115
Oh, I thought it could also work off of the style sheet. I will put the attribute in the tag.
Thanks,
No, it won't look at the css, only the width and height in the image tag.
