How to set up two different payment types for customers at the check out system?
Thread began 11/09/2014 8:47 pm by cj.tung395641 | Last modified 11/13/2014 1:56 pm by Jason Byrnes | 1634 views | 8 replies |
cj.tung395641
Hi there,
I want to provide two different payment choices for customers at the check out system which are 1. credit card 2. invoice(which is showing bank info for customer to complete transaction later.
Thank you very much.
CJ.
Run the checkout wizard twice to create the checkout pages for each payment type.
in the checkout wizard, make sure each set of checkout pages uses unique names.
Then on the cart display page, add checkout buttons for each payment type so the customer can choose which payment method to use.
cj.tung395641
Thanks Jason,
I've already installed PowerStore years ago could you tell me how I can run checkout wizard again? Thanks a lot!
CJ
Oh, sorry, i missed that this was for power store.
for Power Store, this is not supported.
cj.tung395641
Hi Jason,
Then how can I modify the check out? is it possible?
Thank you
CJ
How do you want to modify the checkout?
It is posible to modify, but you will need to edit the code directly.
if you would like help with this, we can help through a premiere support appointment:
http://www.webassist.com/premier_request.php
cj.tung395641
okay, then I should contact premier request, thank you.
CJ
cj.tung395641
Hi Jason,
I've contact premier request. How long usually takes the service to respond me?
Thanks!
CJ
Ray has tried sending a contact request through Skype which you have not yet accepted
