Local Checkout Server Behaviors
Hey guys, here is a quick rundown on what I'm trying to accomplish and what I've tried with no success. Ultimately I'm wanting to use eCart6 but I want to use it with my own checkout form and order history table in the database. This coupled with the fact that eCart6 doesn't yet support MySQLi pretty much excludes using the checkout wizard. So I thought it would be simple enough to use the Local Checkout server behaviors and then use MySQLi to update the DB. After some failures and research I came across this post from Christopher West last month with the same problem of no server behaviors showing up in the window. His post is here: /forums/posts.php?id=35481 . I also have tried to use the checkout wizard and the database tables it created but bypassing the address form which was found here: forums/posts.php?id=28255 which worked well but the process failed. After reading this post: /forums/posts.php?id=33603 I had the same error message of the credentials being wrong despite double checking them with authorize.net and making sure I was using the sandbox.
So, this shopping cart / checkout system is my last major hurdle for this project and I need to close it out soon. I'm willing to pay for the premiere support if it means I can have someone work with me on the process so i can better understand what's going wrong and learn from it.
Here are my questions:
Is there a way to get the "Local Checkout" server behaviors working so i can use my own checkout form and database tables?
If so, then can you confirm that I can still update my tables with MySQLi from somewhere like the success page?
and for Authorize.net:
Is the problem caused by me running this locally using xammp?
does it have to be ran from the server with SSL in place?
If not, how else can I trouble shoot the error with my loginID and Transaction Key?
If this is Jason, you have my Skype contact and as mentioned ( despite this bug for the server behavior issue ) I'm more than willing to pay for the premiere support to get this closed out. I just want to be able to understand the fix and work arounds.
Thanks guys!
