Cannot Activate Data Bridge after updating to most recent version
Thread began 11/02/2014 4:44 pm by Mysite07430650 | Last modified 11/03/2014 3:04 pm by Mysite07430650 | 1468 views | 4 replies |
Mysite07430650
Hello Jason,
I applied the most recent updates to Data Bridge from version 1.1.9 to 1.2.1, Design Extender from version 1.1.7 to 1.1.9, eCart from version 6.0.6 to version 6.1.0 and finally Free Tools from version 1.0.9 to 1.1.1. It goes without saying that previous versions were uninstalled prior to installing the versions mentioned above. Having completed the updates I restarted dreamweaver (CS5.5) and found that Design Extender and Free Tools activated without a problem, however I could not activate Data Bridge and eCart extensions as, the updated extensions did not present the activation dialogue box to input my Serial Numbers.
I have performed the task of closing dreamweaver, locate and deleting WinFileCache.dat file, restart dreamweaver and found I could not activate Data Bridge and eCart. I have also uninstalled all the extensions and re-installed several times and encountered the same problem in the above paragraph.
When I try to start Security Assist it attempts to open but then quickly closes without giving any error message. When I try to start DataAssist or Digital File Upload a dialogue box pops up with the following error message - Error in serialCheck: TypeError: wa.pickDLL is not a function or Uninitialize error: TypeError: wa.pickDLL is not a function respectively.
Please see attached screen capture observing the problem described.
What can I do to rectify this issue?
Thanks.
as a result of compatibility issues with DW CC 2014.1, we are having to completely redo the activation scheme.
eCart 6.1.0, MySQLi 1.0.3 and Data Bridge 1.2.1 use a newer activation scheme, and I think this is causing a conflict with Design Extender 1.1.9 and Free Tools 1.1.1
Those 2 extension will be updated in the next couple of days.
I would uninstall all extensions, then install only eCart, Data Bridge and ySQLi, when the updates for Design Extender and Free tools are released, you can install those.
Mysite07430650
Thanks Jason!
I look forward to the update in 2 days time. Oh by the way, I purchased MySQLi Server Behavior Extension earlier today and wanted to know if there would be problems using it with existing sites that were built without MySQLi SB but used Data Bridge and eCart.
Should I anticipate any compatibility issue in attempting to do this?
Data Bridge has not been updated to use MySQLi yet, eCart should be fine, but data bridge will still use the mySQL library, we are working on upgrading Data Bridge for ySQLi compatibility, but have had to put that on hold to address CC 104.1 issues first.
Mysite07430650
Thanks for the clarification.
