SSL redirect using the same domain name
Thread began 11/02/2014 9:12 am by tmcbinc99963 | Last modified 11/04/2014 3:14 pm by Jason Byrnes | 855 views | 5 replies |
tmcbinc99963
I found a similar question on the forum, but the code provided didn't work for the questioner and the problem transferred to hidden support. The SSL tutorial showed how to redirect to SSL using different domain names, but not for the same domain name.
What is the procedure for SSL redirect using the same domain name? Should only the checkout pages appear in the SSL directory, or all the ecart files? Should the ecart files appear in both secure and insecure areas?
Hi there, I dont know if this may be useful for you, But what I am doing a a complete website redirect to SSL...Im doing the whole website as a secured HTTPS since google is adding https to their SEO algorithm and its stated that in the future they may put more weight on a website having HTTPS so better search results. So I guess there is no harm in doing it now.
so in your .htaccess file add the following code:
RewriteEngine On
RewriteCond %{HTTP_HOST} !^www\. [NC]
RewriteRule ^(.*)$ http://www.your-domain-name.co.uk/$1 [L,R=301]
RewriteCond %{SERVER_PORT} !^443$
RewriteRule ^(.*)$ https://www.your-domain-name.co.uk/$1 [L,R=301]
The above code also handles redirect of non-www to www URLS :)
Chris
tmcbinc99963
Does this mean I won't get a reply from WebAssist?
see this page for details on forcing SSL:
http://www.besthostratings.com/articles/force-ssl-htaccess.html
tmcbinc99963
Not sure I understand this. It seems the htaccess file stays on the main site, but the cart related files go in the ssl directory. Do duplicates of the cart files also need to stay on the main site? Do all the ecart directories (css, etc) move to the ssl directory?
RewriteEngine On
RewriteCond %{SERVER_PORT} 80
RewriteRule ^(.*)$ https://www.example.com/$1 [R,L]
What goes where example.com is - the main site or the first page of the cart? If the main domain, will this redirect the whole site?
you would have a copy of the site in the main directory and in the SSL directory
the hatches file would be at the root of the main site.
example.com would be your site domain
this is really server configuration, so if you have additional questions, you should contact host.
