Bepsoke Power Store
Thread began 10/31/2014 7:42 am by designweb | Last modified 11/12/2014 12:51 pm by Jason Byrnes | 499 views | 5 replies |
designweb
Bepsoke Power Store
If I bought Powerstore, could I use it as a starting point then re-build the front-end responsive and modify the back-end and remove the license?
I just want a starting point framework and make it my own.
Can this be done?
Also can I use Amazon S3 for delivery of digital goods?
Is this easy to set up?
It is posible to use Power Store as a starting point, with power store you have direct access to the code to make any changes you like, we can offer support for this though.
However, you ask about removing the license, that would go against the license agreement for power store. the license agreement does not allow for removal of the power store license.
Power Store does not support using Amazon S3 for digital goods delivery.
designweb
Ok thanks for that.
I can use S3 or Cloud front with eCart though right?
I don't see why not.
designweb
I built a store using an older version of your suite and an older version of eCart. Could I upgrade it using the newer version of you products?
Just don't want to have to build everything again from scratch. Is this possible? Or will there be conflicts.
The site I built in 2008 was www.dto4music.co.uk it would be great just to develop on top of it.
It's posible there may be some conflicts, but i can't really say for certain one way or another.
