Ever since we updated eCart to v6, I keep getting an error pop up in Dreamweaver
Thread began 10/29/2014 7:24 pm by lr_leal239405 | Last modified 2/19/2015 9:09 am by Jason Byrnes | 2334 views | 12 replies |
lr_leal239405
Ever since I updated eCart to v6, I keep getting an error pop up in Dreamweaver. It pops up enough times and I can't get some forms done quickly. "The following translators were not loaded due to errors. WAFB_Form.htm: has configuration information that is invalid". And I already tried deleting the wincachefile [10:10:02 PM] Levin R. Leal: Also. At line 12 of file "C:\Users\Levin\AppData\Roaming\Adobe\DreamweaverCS5\en_US\Configuration\Shared\WebAssist\LayoutManager\shared.js"; wa is not defined [10:10:32 PM] Levin R. Leal: Did the reset layout thing and cleared cache. Already tried resetting layout and then deleting winfilecache as well
resetting the layout and clearing the cache should correct those sorts of errors, sounds like the configuration folder has gone corrupted.
rename the
folder that a contains the cache file.
after renaming the configuration folder, start dreamweaver to recreate it. and close DW.
then open the extension manager, in the extension manager remove all extensions, then reinstall them.
lr_leal239405
Thanks Jason. I ended up upgrading DataAssist with Ray's help. Everything seems to be working ok.
lr_leal239405
(Sorry, I don't see the post button to post another question). I have a cms that doesn't redirect to the detail page after updating, although all the updating is done.....Update or Insert, either doesn't redirect. Can you give me an idea on what it could be? Thank you.
lr_leal239405
ok, glad to hear it is working.
lr_leal239405
After the new installs - using eCart 6.08, when I try open eCart on my page to make some changes, it pops up for less than a second, the closes down immediately. What to do to fix? Thank you
the most recent version of eCart is 6.1.0, you have an older version installed.
close DW and uninstall 6.0.8 from the extension manger, then install the newer one.
lr_leal239405
thanks will try that. Here's another, I've ran the DataBridge pages, for creating a content manager which has the results page, the details page, update page and insert. When I try running them, I get "You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'Desc, Ddate, Dtime FROM bi_main_db LIMIT 0, 10' at line 1' What to do? -
