Assign the 2nd drop down a value of 0 if it has no values
Thread began 10/29/2014 2:41 pm by Larry | Last modified 10/30/2014 1:13 pm by Jason Byrnes | 1256 views | 9 replies |
Larry
I have categories and some have sub categories others do not. If they do not I want the subcategory in the 2nd drop down to be assigned a value of 0.
I had no problem doing this on the insert page but the same method does not work on the update page and a value of null is being inserted instead of 0 and i has to be 0
Category
Book
Gifts
SubCategory
Book > Novel
Book > Reference
set the default value for that column to 0 in the database, that would be the simplest way to go.
Larry
It is but the update form keeps overwriting it inputting null.
send a copy of the update page please.
Larry
Here you go
products_update.php.zip
try adding the following code at line 1:
if(isset($_POST["SubCategoryID"]) && $_POST["SubCategoryID"] == "") {
$_POST["SubCategoryID"] = "0";
Larry
Same thing inserted null
Larry
ok
See pM
