changing my hosting
Thread began 10/28/2014 9:23 am by QuiruNet | Last modified 10/30/2014 1:05 pm by Jason Byrnes | 1522 views | 5 replies |
QuiruNet
changing my hosting
I wanted to know if i have to change my web host, if I have to change the serial number of powerGallery? or reconfigure?. Or only copy all the files to the new hosting it will work as usual?, or i haver to delete the old hosting first?
Copy all the files from the old host to the new host.
You will also need to export the Power Gallery database from the old host and import to the new host using phpMyAdmin, and edit the power gallery connection to use the MySQL database on the new host.
QuiruNet
i have this problem
Warning: mysql_pconnect(): Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /var/www/vhosts/3/169060/webspace/httpdocs/lapostboda.es/Connections/lesmes.php on line 9 Fatal error: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /var/www/vhosts/3/169060/webspace/httpdocs/lapostboda.es/Connections/lesmes.php on line 9
That error means that the host name entered is not correct.
Contact your hot for the correct hostname to use in your connection.
QuiruNet
fix it
now the data base is connect, but i got this message:
SQL error: Error creating fake recordset:
Access denied for user 'u2772479_quiru'@'%' to database 'db2772479_lesmes'
SQL:
SELECT '' AS kt_login_user, '' AS kt_login_password (FIELDS_FAKE_RS_ERROR)
And when i load the databe to the new hosting service, the the table wa_settings change, i send you two attachments with de old hosting and the the hosting.
thanks
That error means that the user and password for connecting to the database are not correct.
this is not the user and password in the wa_settings table, it is the user and password that are set by the host.
contact the host for more assistance.
