Digital File Pro crashes
Thread began 10/23/2014 10:53 am by bjackson5375693 | Last modified 2/09/2015 5:53 pm by bjackson5375693 | 2752 views | 13 replies |
bjackson5375693
I just upgraded to OS X Yosemite. I am using Dreamweaver CS6. I am trying to set up a file upload, however when I select my field name and then go to select "next" the application crashes along with Dreamweaver. I have read a few forum posts and they suggest I delete the MacCache.dat file. I have done this, reset and still get the same crash issue. Help.
What extensions including the version numbers are isntalled?
bjackson5375693
The extensions I have are Databridge 1.2.0. I guess it is called File Manipulation in this version.
bjackson5375693
Web assist Issues?
Jason,
More information on this. It appears to be crashing on my other modules as well. Specifically DataAssist crashes multiple times when I attempt to use this as well.
Seams to be a bug with OS X Yosemite and DW CS 6, I Will log this in our system so it can be fixed in a future update. We're currently working on updates for DW CS2014.1 support, that is a problem in all OS's. So this one will likely happen after that.
bjackson5375693
Jason, can you give me any guesses on a timetable for an update? thanks again.
A couple of weeks at the least, we have to finish updates for DW 2014.1 first.
bjackson5375693
ok, thanks for the update. :)
you're welcome.
bjackson5375693
Hi Jason, I was just checking to see if a pending update was still in the works. Thanks again for your support.
