The catalogue pages are showing at the bottom of the screen
Thread began 10/19/2014 4:38 am by Daniel | Last modified 10/22/2014 1:52 pm by Jason Byrnes | 1642 views | 8 replies |
Daniel
I use a template from CSS sculptor and attempting to create catalogue pages with data assist. The problem is that when I apply the template the forms are all at the bottom of the content page. Can you help please?
I’ve attached some images.
CraigRBeta Tester
The problem is probably down to the clear:both in the form css
It has come up a few times before, take a look at this thread as an example
http://www.webassist.com/forums/posts.php?id=10008
Daniel
Thanks but none of those options seem to be working. This is the generated code:
/* Spry formats */
form.Basic_Default .textfieldRequiredState .textfieldRequiredMsg,
form.Basic_Default .textfieldInvalidFormatState .textfieldInvalidFormatMsg,
form.Basic_Default .textfieldMinValueState .textfieldMinValueMsg,
form.Basic_Default .textfieldMaxValueState .textfieldMaxValueMsg,
form.Basic_Default .textfieldMinCharsState .textfieldMinCharsMsg,
form.Basic_Default .textfieldMaxCharsState .textfieldMaxCharsMsg {
color:#b40000;
white-space:nowrap;
form.Basic_Default .checkboxRequiredState .checkboxRequiredMsg,
form.Basic_Default .checkboxMinSelectionsState .checkboxMinSelectionsMsg,
form.Basic_Default .checkboxMaxSelectionsState .checkboxMaxSelectionsMsg {
color:#b40000;
white-space:nowrap;
form.Basic_Default .selectRequiredState .selectRequiredMsg,
form.Basic_Default .selectInvalidState .selectInvalidMsg {
color:#b40000;
white-space:nowrap;
form.Basic_Default .textareaRequiredState .textareaRequiredMsg,
form.Basic_Default .textareaMinCharsState .textareaMinCharsMsg,
form.Basic_Default .textareaMaxCharsState .textareaMaxCharsMsg {
color:#b40000;
white-space:nowrap;
form.Basic_Default .radioRequiredState .radioRequiredMsg,
form.Basic_Default .radioInvalidState .radioInvalidMsg {
color:#b40000;
white-space:nowrap;
form.Basic_Default .passwordRequiredState .passwordRequiredMsg,
form.Basic_Default .passwordMinCharsState .passwordMinCharsMsg,
form.Basic_Default .passwordMaxCharsState .passwordMaxCharsMsg,
form.Basic_Default .passwordInvalidStrengthState .passwordInvalidStrengthMsg,
form.Basic_Default .passwordCustomState .passwordCustomMsg {
color:#b40000;
white-space:nowrap;
form.Basic_Default .confirmRequiredState .confirmRequiredMsg,
form.Basic_Default .confirmInvalidState .confirmInvalidMsg {
color:#b40000;
white-space:nowrap;
/* The next three group selectors control the way the core element (TEXTAREA) looks like when the widget is in one of the states: * focus, required / minChars / maxChars , valid
* There are two selectors for each state, to cover the two main usecases for the widget:
* - the widget id is placed on the top level container for the TEXTAREA
* - the widget id is placed on the TEXTAREA element itself (there are no error messages)
/* When the widget is in the valid state the TEXTAREA has a green background applied on it. */
form.Basic_Default .textareaValidState textarea, textarea.textareaValidState {
background-color:#B8F5B1;
/* When the widget has received focus, the TEXTAREA has a yellow background applied on it. */
form.Basic_Default .textareaFocusState textarea, textarea.textareaFocusState {
background-color:#FFFFCC;
/* This class applies only for a short period of time and changes the way the text in the textarea looks like.
* It applies only when the widget has enforce max chars enabled and the user tries to type some more.
form.Basic_Default .textareaFlashState textarea, textarea.textareaFlashState{
color: #ff0000;
/* When the widget has the hint message on, the hint text can be styled differently than the user typed text. */
form.Basic_Default textarea.textareaHintState, .textareaHintState textarea{
color: #Ff0000;
/* The next three group selectors control the way the core element (INPUT) looks like when the widget is in one of the states: * focus, required / invalid / minValue / maxValue / minChars / maxChars , valid
* - the widget id is placed on the top level container for the INPUT
* - the widget id is placed on the INPUT element itself (there are no error messages)
/* When the widget is in the valid state the INPUT has a green background applied on it. */
form.Basic_Default .textfieldValidState input, input.textfieldValidState {
/* When the widget is in an invalid state the INPUT has a red background applied on it. */
form.Basic_Default input.textfieldRequiredState, .textfieldRequiredState input,
form.Basic_Default input.textfieldInvalidFormatState, .textfieldInvalidFormatState input,
form.Basic_Default input.textfieldMinValueState, .textfieldMinValueState input,
form.Basic_Default input.textfieldMaxValueState, .textfieldMaxValueState input,
form.Basic_Default input.textfieldMinCharsState, .textfieldMinCharsState input,
form.Basic_Default input.textfieldMaxCharsState, .textfieldMaxCharsState input {
background-color:#FF9F9F;
/* When the widget has received focus, the INPUT has a yellow background applied on it. */
form.Basic_Default .textfieldFocusState input, input.textfieldFocusState {
/* This class applies only for a short period of time and changes the way the text in the textbox looks like.
* It applies only when the widget has character masking enabled and the user tries to type in an invalid character.
form.Basic_Default .textfieldFlashText input, input.textfieldFlashText {
color: #ff0000;
form.Basic_Default .textfieldHintState input, input.textfieldHintState {
color: #ff0000;
/* select */
/* The next three group selectors control the way the core element (SELECT) looks like when the widget is in one of the states:
* focus, required / invalid, valid
* - the widget id is placed on the top level container for the SELECT
* - the widget id is placed on the SELECT element itself (there are no error messages)
/* When the widget is in the valid state the SELECT has a green background applied on it. */
form.Basic_Default .selectValidState select, select.selectValidState {
/* When the widget is in an invalid state the SELECT has a red background applied on it. */
form.Basic_Default select.selectRequiredState, .selectRequiredState select,
form.Basic_Default select.selectInvalidState, .selectInvalidState select {
/* When the widget has received focus, the SELECT has a yellow background applied on it. */
form.Basic_Default .selectFocusState select, select.selectFocusState {
/* Password */
display: inline;
color: #CC3333;
border: 1px solid #CC3333;
/* The next three group selectors control the way the core element (INPUT) looks like when the widget is in one of the states: * focus, required / invalid Strength / minValue / maxValue / custom invalid , valid
form.Basic_Default .passwordValidState input, input.passwordValidState {
form.Basic_Default .passwordFocusState input, input.passwordFocusState {
/* confirm */
/* The next three group selectors control the way the core element (INPUT) looks like when the widget is in one of the states: * focus, required , invalid , valid
form.Basic_Default .confirmValidState input, input.confirmValidState {
form.Basic_Default input.confirmRequiredState, .confirmRequiredState input,
form.Basic_Default input.confirmInvalidState, .confirmInvalidState input
form.Basic_Default .confirmFocusState input, input.confirmFocusState {
form.Basic_Default span.additionalErrorZone {
white-space:nowrap;
form.Basic_Default div.errorGroup {
margin-left:125px;
form.Basic_Default span.serverInvalidState {
color:#b40000;
white-space:nowrap;
/* form general definition */
form.Basic_Default {
width:500px;
form.DetailsPage {
width: auto;
form.Basic_Default ul.Basic_Default {
list-style-type:none;
margin: 0;
padding: 0;
form.Basic_Default ul.formList {
padding:0 0 0 0;
margin:0 0 0 0;
form.Basic_Default li.formItem {
clear:both;
form.Basic_Default fieldset.Basic_Default {
clear:right;
padding-bottom:12px;
/* legend */
form.Basic_Default legend.groupHeader {
font-weight:bold;
font-size:larger;
white-space:nowrap;
/* labels */
form.Basic_Default label.groupHeader {
text-align:right;
display:block;
float:left;
position:relative;
form.Basic_Default label.sublabel, form.Basic_Default td.DetailsPage, form.Basic_Default td.DetailsSublabel {
font-weight:normal;
text-align:right;
width:120px;
float:left;
display:block;
margin-top:5px;
margin-bottom:5px;
padding-right:5px;
form.Basic_Default td.DetailsPage {
width:auto;
text-align:left;
display:table-cell;
text-align:right;
display:table-cell;
float:left;
form.Basic_Default label.secondSublabel {
width:auto;
form.Basic_Default label.sublabelPlaceholder {
form.Basic_Default span.requiredIndicator {
color:#b40000;
form.Basic_Default span.fieldsetDescription {
color:#b40000;
/* span wrappers for form */
form.Basic_Default div.formGroup {
display:inline;
float:left;
form.Basic_Default div.lineGroup {
clear:left;
display:block;
/* defines column size */
form.Basic_Default div.wideColumnGroup {
width:-26px;
padding-bottom:15px;
padding-top:7px;
display:inline;
float:left;
form.Basic_Default div.fullColumnGroup {
width:474px;
padding-top:7px;
display:inline;
float:left;
form.Basic_Default div.columnGroup {
width:500px;
padding-top:7px;
display:inline;
float:left;
form.Basic_Default div.fieldGroup {
padding-left:0;
padding-right:0;
position:relative;
display:block;
float:left;
form.Basic_Default div.fieldPair {
display:block;
form.Basic_Default div.SameAsCheck_Row {
form.Basic_Default span.precedingText {
text-align:right;
font-weight: bold;
form.Basic_Default div.trailingText {
white-space:nowrap;
form.Basic_Default div.trailingText a {
form.Basic_Default div.trailingText div {
background-color:#8c8c8c;
/* wide groups for items on a single line */
form.Basic_Default span.wideFieldGroup {
width:100%;
float:left;
/* button form elements */
form.Basic_Default span.buttonFieldGroup {
float:left;
text-align:right;
padding-top:15px;
padding-left:125px;
form.Basic_Default input.formButton {
margin: 0;
padding: 0;
/* text form elements */
form.Basic_Default input.formTextfield_XSmall {
background-color:#FFF;
padding:5px 5px 5px 5px;
width:50px;
margin:0;
margin-left:2px;
form.Basic_Default input.formTextfield_Small {
width:80px;
margin:0;
margin-left:2px;
form.Basic_Default input.formTextfield_Medium {
width:120px;
margin:0;
margin-left:2px;
form.Basic_Default input.formTextfield_Large {
width:200px;
margin:0;
margin-left:2px;
form.Basic_Default input.formTextfield_XLarge {
width:592px;
margin:0;
margin-left:2px;
form.Basic_Default .textfieldValidState input, form.Basic_Default input.textfieldValidState {
background-color: #B8F5B1;
form.Basic_Default input.textfieldRequiredState, form.Basic_Default .textfieldRequiredState input,
form.Basic_Default input.textfieldInvalidFormatState, form.Basic_Default .textfieldInvalidFormatState input,
form.Basic_Default input.textfieldMinValueState, form.Basic_Default .textfieldMinValueState input,
form.Basic_Default input.textfieldMaxValueState, form.Basic_Default .textfieldMaxValueState input,
form.Basic_Default input.textfieldMinCharsState, form.Basic_Default .textfieldMinCharsState input,
form.Basic_Default input.textfieldMaxCharsState, form.Basic_Default .textfieldMaxCharsState input {
background-color: #FF9F9F;
form.Basic_Default .textfieldFocusState input, form.Basic_Default input.textfieldFocusState {
background-color: #FFFFCC;
form.Basic_Default .textfieldFlashText input, form.Basic_Default input.textfieldFlashText {
color: red !important;
form.Basic_Default .textfieldHintState input, form.Basic_Default input.textfieldHintState {
/*color: red !important;*/
/* textarea form elements */
form.Basic_Default textarea.formTextarea_Small {
width:252px;
height:100px;
white-space:pre;
overflow:auto;
margin:0;
margin-left:2px;
form.Basic_Default textarea.formTextarea_Medium {
width:382px;
height:150px;
white-space:pre;
overflow:auto;
margin:0;
margin-left:2px;
form.Basic_Default textarea.formTextarea_Large {
width:514px;
height:200px;
white-space:pre;
overflow:auto;
margin:0;
margin-left:2px;
form.Basic_Default .textareaValidState textarea, form.Basic_Default textarea.textareaValidState {
form.Basic_Default textarea.textareaRequiredState, form.Basic_Default .textareaRequiredState textarea,
form.Basic_Default textarea.textareaMinCharsState, form.Basic_Default .textareaMinCharsState textarea,
form.Basic_Default textarea.textareaMaxCharsState, form.Basic_Default .textareaMaxCharsState textarea {
form.Basic_Default .textareaFocusState textarea, form.Basic_Default textarea.textareaFocusState {
form.Basic_Default .textareaFlashState textarea, form.Basic_Default textarea.textareaFlashState{
color:red !important;
form.Basic_Default textarea.textareaHintState, form.Basic_Default .textareaHintState textarea{
/* color: red !important;*/
/* select form elements */
form.Basic_Default select.formMenufield_XSmall {
width:50px;
margin:0;
margin-left:2px;
form.Basic_Default select.formMenufield_Small {
width:80px;
margin:0;
margin-left:2px;
form.Basic_Default select.formMenufield_Medium {
width:120px;
margin:0;
margin-left:2px;
form.Basic_Default select.formMenufield_Large {
width:252px;
margin:0;
margin-left:2px;
form.Basic_Default select.formMenufield_XLarge {
width:382px;
margin:0;
margin-left:2px;
form.Basic_Default select.formListfield_XSmall {
width:50px;
height:100px;
margin:0;
margin-left:2px;
form.Basic_Default select.formListfield_Small {
width:80px;
height:100px;
margin:0;
margin-left:2px;
form.Basic_Default select.formListfield_Medium {
width:120px;
height:100px;
margin:0;
margin-left:2px;
form.Basic_Default select.formListfield_Large {
width:252px;
height:100px;
margin:0;
margin-left:2px;
form.Basic_Default select.formListfield_XLarge {
width:382px;
height:150px;
margin:0;
margin-left:2px;
form.Basic_Default .selectValidState select, form.Basic_Default select.selectValidState {
form.Basic_Default select.selectRequiredState, form.Basic_Default .selectRequiredState select,
form.Basic_Default select.selectInvalidState, form.Basic_Default .selectInvalidState select {
.selectFocusState select, form.Basic_Default select.selectFocusState {
/* radio button form elements */
form.Basic_Default input.formRadioField_Standard {
padding:2px 2px 2px 2px;
margin-left:2px;
form.Basic_Default .radioValidState input, form.Basic_Default input.radioValidState {
form.Basic_Default input.radioRequiredState, form.Basic_Default .radioRequiredState input,
form.Basic_Default input.radioInvalidState, form.Basic_Default .radioInvalidState input {
form.Basic_Default .radioFocusState input, form.Basic_Default input.radioFocusState {
form.Basic_Default span.radioFieldGroup_Narrow {
form.Basic_Default span.radioFieldGroup_Wide {
display:block;
form.Basic_Default span.radioFieldGroup_OneColumn {
display:block;
form.Basic_Default span.radioGroup_Narrow {
form.Basic_Default span.radioGroup_Wide {
display:block;
form.Basic_Default span.radioGroup_OneColumn {
display:block;
form.Basic_Default label.radioSublabel_Narrow {
font-weight:normal;
width:60px;
float:left;
display:block;
text-align:left;
form.Basic_Default label.radioSublabel_Wide {
font-weight:normal;
width:135px;
float:left;
display:block;
text-align:left;
form.Basic_Default label.radioSublabel_OneColumn {
font-weight:normal;
display:block;
text-align:left;
/* checkbox form elements */
form.Basic_Default input.SameAsCheck {
margin-left:2px;
form.Basic_Default input.formCheckboxField_Standard {
margin-left:2px;
form.Basic_Default .checkboxValidState input, form.Basic_Default input.checkboxValidState {
form.Basic_Default input.checkboxRequiredState, form.Basic_Default .checkboxRequiredState input,
form.Basic_Default input.checkboxMinSelectionsState, form.Basic_Default .checkboxMinSelectionsState input,
form.Basic_Default input.checkboxMaxSelectionsState, form.Basic_Default .checkboxMaxSelectionsState input {
form.Basic_Default .checkboxFocusState input, form.Basic_Default input.checkboxFocusState {
form.Basic_Default span.checkFieldGroup_Narrow {
display:block;
form.Basic_Default span.checkFieldGroup_Wide {
form.Basic_Default span.checkFieldGroup_OneColumn {
display:block;
form.Basic_Default span.checkGroup_Narrow {
display:block;
form.Basic_Default span.checkGroup_Wide {
form.Basic_Default span.checkGroup_OneColumn {
display:block;
form.Basic_Default label.checkSublabel_Narrow {
font-weight:normal;
width:60px;
float:left;
display:block;
text-align:left;
form.Basic_Default label.checkSublabel_Wide {
font-weight:normal;
width:135px;
float:left;
display:block;
text-align:left;
form.Basic_Default label.checkSublabel_OneColumn {
font-weight:normal;
display:block;
text-align:left;
/* confirm and password states (same as text) */
form.Basic_Default input.formPasswordfield_XSmall {
width:50px;
margin:0;
margin-left:2px;
form.Basic_Default input.formPasswordfield_Small {
width:80px;
margin:0;
margin-left:2px;
form.Basic_Default input.formPasswordfield_Medium {
width:120px;
margin:0;
margin-left:2px;
form.Basic_Default input.formPasswordfield_Large {
width:200px;
margin:0;
margin-left:2px;
form.Basic_Default input.formPasswordfield_XLarge {
width:592px;
margin:0;
margin-left:2px;
form.Basic_Default .confirmValidState input, form.Basic_Default input.confirmValidState {
form.Basic_Default input.confirmRequiredState, form.Basic_Default .confirmRequiredState input,
form.Basic_Default input.confirmInvalidState, form.Basic_Default .confirmInvalidState input {
form.Basic_Default .confirmFocusState input, form.Basic_Default input.confirmFocusState {
form.Basic_Default .passwordValidState input, form.Basic_Default input.passwordValidState {
form.Basic_Default input.passwordRequiredState, form.Basic_Default .passwordRequiredState input,
form.Basic_Default input.passwordInvalidStrengthState, form.Basic_Default .passwordInvalidStrengthState input,
form.Basic_Default input.passwordMinCharsState, form.Basic_Default .passwordMinCharsState input,
form.Basic_Default input.passwordCustomState, form.Basic_Default .passwordCustomState input,
form.Basic_Default input.passwordMaxCharsState, form.Basic_Default .passwordMaxCharsState input {
form.Basic_Default .passwordFocusState input, form.Basic_Default input.passwordFocusState {
/*Captcha form element*/
form.Basic_Default img.Captcha {
margin:0 0 -7px 2px;
/*Datepicker form element*/
.ui-datepicker {
.ui-datepicker a {
.ui-datepicker .ui-widget-header {
.ui-datepicker thead th {
.ui-datepicker tbody td a:link,
.ui-datepicker tbody td a:visited,
.ui-datepicker tbody td a.ui-state-default {
.ui-datepicker tbody td a:active,
.ui-datepicker tbody td a.ui-state-active {
.ui-datepicker tbody td a:hover,
.ui-datepicker tbody td a.ui-state-hover {
.ui-datepicker tbody td a.ui-state-error:link,
.ui-datepicker tbody td a.ui-state-error:visited,
.ui-datepicker tbody td a.ui-state-error {
.ui-datepicker tbody .ui-state-error-text {
.ui-datepicker tbody td.ui-datepicker-week-end a:link,
.ui-datepicker tbody td.ui-datepicker-week-end a:visited,
.ui-datepicker tbody td.ui-datepicker-week-end a {
.ui-datepicker tbody td.ui-datepicker-today a:link,
.ui-datepicker tbody td.ui-datepicker-today a:visited,
.ui-datepicker tbody td.ui-datepicker-today a:hover,
.ui-datepicker tbody td.ui-datepicker-today a {
.ui-datepicker tbody td.ui-datepicker-week-end a:hover,
.ui-datepicker tbody td.ui-datepicker-week-end a.ui-state-hover {
.ui-datepicker tbody td.ui-datepicker-week-end a:active,
.ui-datepicker tbody td.ui-datepicker-week-end a:focus,
.ui-datepicker tbody td.ui-datepicker-week-end a.ui-state-active {
.ui-datepicker-trigger {
border: 0;
margin: 0 0 0 1px;
padding: 0;
background: none;
form.Basic_Default .TextOnly {
padding-top: 5px;
display: table-cell;
Provide a link where I can see the problem.
When reporting a design problem, you should always include a link.
Daniel
I'm developing everything locally which is going to make that difficult. I'll see if can get everything uploaded.
Thanks.
Daniel
Hi, I've managed to put online so you can have a look
http://www.vials.co.uk/products_detail.php
Thank you.
in screen css, add overflow: hidden to #outerWrapper #contentWrapper #content:
#outerWrapper #contentWrapper #content {
margin: 0 16em;
overflow: hidden;
padding: 10px 20px 20px;
Daniel
Thank you Jason, much apreciated!
you're welcome.
