What code governs the width of the middle pod?
HI
I want the middle pod to be the width of the page
which code controls this
thanks
Ian
HI
thanks
Ian
This is not going to be a simple modification, there is no single code edit to make that will accomplish this.
You would need to rearrange the left, middle and right box divs in the tempalte so that the middle box is in a separate content div and then add a css class specifically for the middle pod.
If you need help with this, please submit a premiere support request:
http://www.webassist.com/premier_request.php
