How to make Horizontal Menu drop Up not Down?
Hello,
I'm adding a Horizontal Menu to a footer so would need this to Drop Up not Drop Down. Is there a known css change that needs be put in place to create this condition?
Hello,
you could try adding a negative top margin to the main levels group.
This may be problematic though since the value for the top margin will need to be the height of the sub menu, and may change from menu item to menu item.
