eCart - checkout page form field persistence after advancing to confirm page - then going back to checkout page
Thread began 10/15/2014 4:03 pm by dlovas275157 | Last modified 10/16/2014 1:19 pm by Jason Byrnes | 479 views | 6 replies |
dlovas275157
I built my ecommerce checkout with eCart5
The checkout process is as follows:
cart page (cart/index.php)
checkout page (cart/checkout.php)
confirm page (cart/confirm.php)
checkout success / checkout failure page (cart/checkout_success.php, cart/checkout_failure.php)
Issue - If I have added to cart, filled out the checkout page and proceeded on to the confirm page, but them decide to go back a step to the checkout page, all the form fields in the checkout page need to be re-entered. How do i get them to retain?
Attached are my checkout and confirm pages. I noticed on the confirm page, session values are set from the checkout form post vars, but not sure how to pull them back in. My init values on the checkout page are set to the validated entries currently.
The information entered on the checkout page is saved to session variables,
use the session variable bindings for the initial value of the form elements to have the information populated on going back to the checkout page.
dlovas275157
The init values are currently set to the validated entries so if it fails validation , they remain:
<input type="text" name="firstname" id="firstname" value="<?php echo ((ValidatedField("confirm_386","firstname") != "")?ValidatedField("confirm_386","firstname"):$row_rsUser['firstName']) ?>" style="width:150px" />
Just not sure how to have the init vals set to both validated entry and the session value?
(Tried to post files, but the upload files does not seem to be working. Tried on multiple computers).
<input type="text" name="firstname" id="firstname" value="<?php echo ((ValidatedField("confirm_386","firstname") != "")?ValidatedField("confirm_386","firstname"):$_SESSION['eCartCheckoutForm_firstname']) ?>" style="width:150px" />
dlovas275157
Jason,
Thanks for the quick response. I will give this a try and post back results.
thnx
DL
dlovas275157
Jason,
Is there a way to incorporate from my original code :$row_rsUser['firstName'] as the fallback init if BOTH the validated field is empty AND the session var is empty. This occurs when the user comes to the checkout form for the first time after logging in to his/her account.
The rsUser value populates the field if the user is logged into their account and has previously saved their name to his/her profile.
Not sure how to pull all three options in.
ok, to tie all 3 together, use:
<input type="text" name="firstname" id="firstname" value="<?php echo ((ValidatedField("confirm_386","firstname") != "")?ValidatedField("confirm_386","firstname"):(($_SESSION['eCartCheckoutForm_firstname'] != "")?$_SESSION['eCartCheckoutForm_firstname']:$row_rsUser['firstName'])) ?>" style="width:150px" />
