activation of databridge
Hi have the databridge extension, after installing an update <moved to private> keeps returning incorrect
when you copy the key, make sure thou are not selecting any surrounding spaces, paste the key into the first box of the activation window, it will be broken up automatically, normally if you have a correct key and are getting the error that it is incorrect, it means you are selecting surrounding spaces.
if you continue to have the same error, please send a screen shot of the activation window showing the problem.
