I have a checkbox in my form that when checked I would like to have a text field below ungray "activate" to accept input. Otherwise remain grayed out.
Thread began 10/13/2014 7:45 am by MrProDesignWebsites | Last modified 10/16/2014 2:53 pm by CraigR | 937 views | 5 replies |
MrProDesignWebsites
I am trying to set up a checkbox in my form that is conditional. When unchecked you can see a grayed out text field directly below. When the checkbox is checked I would like the text field to activate to accept input. Is there a way to do this?
Thanks.
CraigRBeta Tester
I'm still learning jquery, but I think this should work for you...
(textbox with an id of text1 and a checkbox of class checkbox)
<script>
$(document).ready(function(){
$('#text1').prop("disabled", true);
$('.checkbox').click(function() {
if ($("#text1").prop("disabled")) {
$("#text1").prop("disabled", false);
} else {
$("#text1").prop("disabled", true);
</script>
MrProDesignWebsites
Can you tell me where this should appear in my form? I'm not sure where this should be plugged in - thanks!
CraigRBeta Tester
you need to put a line in the <head> section of your site referencing the jquery library (if you haven't already done so)
this can be a link to the jquery site itself, or locally, as you may already have it installed if you use webassist extensions.
look for a file called jquery-(version number).min.js or jquery-(version number).js
the code i posted can go anywhere on the page AFTER the jquery line, either in the head or the body section, but must be enclosed within the script tags
for reference...http://www.w3schools.com/js/js_whereto.asp
MrProDesignWebsites
This worked! When the checkbox is unchecked no input can be made into the text box. Once checked the checkbox it allows input. So, now how do I make it so the text box is a different color in the unchecked state to make it visually appear unavailable for input like grayed out or whatever color I would like to designate this? Once checked it should return to default input color.
CraigRBeta Tester
you need to manipulate the css of the text box using jquery
eg you could try the toggle class method
http://www.w3schools.com/jquery/html_toggleclass.asp
