<?php require_once("webassist/form_validations/wavt_scripts_php.php"); ?>
<?php require_once('Connections/connMoonshine.php'); ?>
<?php require_once("webassist/form_validations/wavt_validatedform_php.php"); ?>
if ((isset($_POST["Insert"]) || isset($_POST["Insert_x"]))) {
$WAFV_Redirect = "".(htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)) ."?invalid=true";
$_SESSION['WAVT_join_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateNM((isset($_POST["member_id"])?$_POST["member_id"]:"") . "","","",0,",.",false,1);
$WAFV_Errors .= WAValidateRQ((isset($_POST["first_name"])?$_POST["first_name"]:"") . "",true,2);
$WAFV_Errors .= WAValidateRQ((isset($_POST["last_name"])?$_POST["last_name"]:"") . "",true,3);
$WAFV_Errors .= WAValidateEM((isset($_POST["email"])?$_POST["email"]:"") . "",true,4);
$WAFV_Errors .= WAValidateZC((isset($_POST["zip_code"])?$_POST["zip_code"]:"") . "",true,false,false,false,true,5);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"join");
<?php require_once("webassist/database_management/wa_appbuilder_php.php"); ?>
<?php require_once("webassist/email/mail_php.php"); ?>
<?php require_once("webassist/email/mailformatting_php.php"); ?>
// WA DataAssist Insert
if (isset($_POST["Insert"]) || isset($_POST["Insert_x"])) // Trigger
$WA_connection = $connMoonshine;
$WA_table = "Members";
$WA_sessionName = "WADA_Insert_Members";
$WA_redirectURL = "join-TY.php";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_fieldNamesStr = "member_id|first_name|last_name|email|zip_code";
$WA_fieldValuesStr = "".((isset($_POST["member_id"]))?$_POST["member_id"]:"") ."" . $WA_AB_Split . "".((isset($_POST["first_name"]))?$_POST["first_name"]:"") ."" . $WA_AB_Split . "".((isset($_POST["last_name"]))?$_POST["last_name"]:"") ."" . $WA_AB_Split . "".((isset($_POST["email"]))?$_POST["email"]:"") ."" . $WA_AB_Split . "".((isset($_POST["zip_code"]))?$_POST["zip_code"]:"") ."";
$WA_columnTypesStr = "',none,''|',none,''|',none,''|',none,''|',none,''";
$WA_fieldValues = explode($WA_AB_Split, $WA_fieldValuesStr);
$WA_connectionDB = $database_connMoonshine;
@session_start();
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id($WA_connection);
if ($WA_redirectURL != "") {
$WA_redirectURL = str_replace("[Insert_ID]",$_SESSION[$WA_sessionName],$WA_redirectURL);
//WA Universal Email object="mail"
@session_write_close();
set_time_limit(0);
$EmailRef = "waue_join_1";
$BurstSize = 200;
$BurstTime = 1;
$WaitTime = 1;
$GoToPage = "join-TY.php";
$RecipArray = array();
$StartBurst = time();
$LoopCount = 0;
$TotalEmails = 0;
$RecipIndex = 0;
// build up recipients array
$CurIndex = sizeof($RecipArray);
$RecipArray[$CurIndex] = array();
$RecipArray[$CurIndex ][] = "".((isset($_POST["email"]))?$_POST["email"]:"") ."";
$TotalEmails += sizeof($RecipArray[$CurIndex]);
$RealWait = ($WaitTime<0.25)?0.25:($WaitTime+0.1);
$TimeTracker = Array();
$TotalBursts = floor($TotalEmails/$BurstSize);
$AfterBursts = $TotalEmails % $BurstSize;
$TimeRemaining = ($TotalBursts * $BurstTime) + ($AfterBursts*$RealWait);
if ($TimeRemaining < ($TotalEmails*$RealWait) ) {
$TimeRemaining = $TotalEmails*$RealWait;
writeUEProgress($EmailRef,0,$TotalEmails,$TimeRemaining);
while ($RecipIndex < sizeof($RecipArray)) {
$EnteredValue = is_string($RecipArray[$RecipIndex][0]);
$CurIndex = 0;
while (($EnteredValue && $CurIndex < sizeof($RecipArray[$RecipIndex])) || (!$EnteredValue && $RecipArray[$RecipIndex][0])) {
$starttime = microtime_float();
if ($EnteredValue) {
$RecipientEmail = $RecipArray[$RecipIndex][$CurIndex];
} else {
$RecipientEmail = $RecipArray[$RecipIndex][0][$RecipArray[$RecipIndex][2]];
$EmailsRemaining = ($TotalEmails- $LoopCount);
$BurstsRemaining = ceil(($EmailsRemaining-$AfterBursts)/$BurstSize);
$IntoBurst = ($EmailsRemaining-$AfterBursts) % $BurstSize;
if ($AfterBursts<$EmailsRemaining) $IntoBurst = 0;
$TimeRemaining = ($BurstsRemaining * $BurstTime * 60) + ((($AfterBursts<$EmailsRemaining)?$AfterBursts:$EmailsRemaining)*$RealWait) - (($AfterBursts>$EmailsRemaining)?0:($IntoBurst*$RealWait));
if ($TimeRemaining < ($EmailsRemaining*$RealWait) ) {
$TimeRemaining = $EmailsRemaining*$RealWait;
$CurIndex ++;
$LoopCount ++;
writeUEProgress($EmailRef,$LoopCount,$TotalEmails,round($TimeRemaining));
wa_sleep($WaitTime);
include("webassist/email/waue_join_1.php");
$endtime = microtime_float();
$TimeTracker[] =$endtime - $starttime;
$RealWait = array_sum($TimeTracker)/sizeof($TimeTracker);
if ($LoopCount % $BurstSize == 0 && $CurIndex < sizeof($RecipArray[$RecipIndex])) {
$TimePassed = (time() - $StartBurst);
if ($TimePassed < ($BurstTime*60)) {
$WaitBurst = ($BurstTime*60) -$TimePassed;
wa_sleep($WaitBurst);
else {
$TimeRemaining = ($TotalEmails- $LoopCount)*$RealWait;
if (!$EnteredValue) {
$RecipArray[$RecipIndex][0] = mysql_fetch_assoc($RecipArray[$RecipIndex][1]);
$RecipIndex ++;
@session_start();
$_SESSION[$EmailRef."_Status"] = $GLOBALS[$EmailRef."_Status"];
$_SESSION[$EmailRef."_Index"] = $GLOBALS[$EmailRef."_Index"];
$_SESSION[$EmailRef."_From"] = $GLOBALS[$EmailRef."_From"];
$_SESSION[$EmailRef."_To"] = $GLOBALS[$EmailRef."_To"];
$_SESSION[$EmailRef."_Subject"] = $GLOBALS[$EmailRef."_Subject"];
$_SESSION[$EmailRef."_Body"] = $GLOBALS[$EmailRef."_Body"];
$_SESSION[$EmailRef."_Header"] = $GLOBALS[$EmailRef."_Header"];
$_SESSION[$EmailRef."_Log"] = $GLOBALS[$EmailRef."_Log"];
if (function_exists("rel2abs")) $GoToPage = $GoToPage?rel2abs($GoToPage,dirname(__FILE__)):"";
if ($GoToPage!="") {
header("Location: ".$GoToPage);
set_time_limit(0);
$EmailRef = "waue_join_2";
$BurstSize = 200;
$BurstTime = 1;
$WaitTime = 1;
$LoopCount = 0;
$TotalEmails = 0;
$RecipIndex = 0;
$CurIndex = 0;
} else {
$CurIndex ++;
$LoopCount ++;
include("webassist/email/waue_join_2.php");
else {
$RecipIndex ++;
@session_start();
<!doctype html>
<html>
<head>
<meta charset="utf-8">
<link href='http://fonts.googleapis.com/css?family=Ubuntu:400,700' rel='stylesheet' type='text/css'>
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<title>Moonshine Network New Member Registration</title>
<link rel="stylesheet" type="text/css" href="css/styles.css">
<link rel="stylesheet" type="text/css" href="css/menu.css">
<!--[if lt IE 9]>
<script src="http://html5shim.googlecode.com/svn/trunk/html5.js"></script>
<![endif]-->
<script src="webassist/progress_bar/jquery-blockui-formprocessing.js" type="text/javascript"></script>
<link href="webassist/forms/fd_sidebar_default.css" rel="stylesheet" type="text/css">
<link rel="stylesheet" href="webassist/jq_validation/Bloom.css">
<script src="//ajax.googleapis.com/ajax/libs/jquery/1/jquery.min.js"></script>
<script src="//ajax.googleapis.com/ajax/libs/jqueryui/1/jquery-ui.min.js"></script>
<link href="webassist/forms/dataassist_button.css" rel="stylesheet" type="text/css" />
</head>
<body>
<div id="wrapper100">
<div class="head_line"></div>
<div class="wrapper">
<div class="logo"><?php require_once('includes/logo.php'); ?>
<!-- end logo --></div>
<!-- head_block --><div class="head_block">
<div class="nav-top">
<?php require_once('includes/nav-top.php'); ?>
<!-- end nav --></div>
<div class="header">
<div class="tag"><?php require_once('includes/tag.php'); ?>
<!-- end phone --></div>
<!-- //header --></div>
<div class="clear"></div>
<!-- end head_block --></div>
<!-- main nav -->
<?php require_once('includes/main-nav.php'); ?>
<!-- end main nav -->
<div class="main">
<p align="center"><b>Please complete the information below. <br>
Your Moonshine Network Member ID will be emailed to you.</b></p>
<div align="center" id="Insert_Sidebar_Default_ProgressWrapper">
<form class="Sidebar_Default" id="Insert_Sidebar_Default" name="Insert_Sidebar_Default" method="post" action="<?php echo (htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?>">
<ul class="Sidebar_Default">
<li>
<fieldset class="Sidebar_Default" id="Insert">
<ul class="formList">
<li class="formItem">
<div class="formGroup">
<div class="lineGroup">
<!--<div class="fullColumnGroup"><label for="member_id" class="sublabel" >Member ID:</label>
<input id="member_id" name="member_id" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("join","member_id"):"")); ?>" class="formTextfield_Medium" tabindex="1" title="Please enter a value.">
if (ValidatedField('join','join')) {
if ((strpos((",".ValidatedField("join","join").","), "," . "1" . ",") !== false || "1" == "")) {
if (!(false)) {
?><span class="serverInvalidState" id="member_id_ServerError">Please enter a value.</span><?php //WAFV_Conditional join.php join(1:)
</div>-->
</div>
</div>
</li>
<div class="fullColumnGroup"><label for="first_name" class="sublabel" >First Name:<span class="requiredIndicator"> *</span></label>
<input id="first_name" name="first_name" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("join","first_name"):"")); ?>" class="formTextfield_Medium" tabindex="2" title="Please enter a value." required>
if ((strpos((",".ValidatedField("join","join").","), "," . "2" . ",") !== false || "2" == "")) {
if (!(false)) {
?><span class="serverInvalidState" id="first_name_ServerError">Please enter a value.</span><?php //WAFV_Conditional join.php join(2:)
</div>
</div>
</div>
</li>
<div class="fullColumnGroup"><label for="last_name" class="sublabel" >Last Name:<span class="requiredIndicator"> *</span></label>
<input id="last_name" name="last_name" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("join","last_name"):"")); ?>" class="formTextfield_Medium" tabindex="3" title="Please enter a value." required>
if ((strpos((",".ValidatedField("join","join").","), "," . "3" . ",") !== false || "3" == "")) {
if (!(false)) {
?><span class="serverInvalidState" id="last_name_ServerError">Please enter a value.</span><?php //WAFV_Conditional join.php join(3:)
</div>
</div>
</div>
</li>
<div class="fullColumnGroup"><label for="email" class="sublabel" >Email Address:<span class="requiredIndicator"> *</span></label>
<input id="email" name="email" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("join","email"):"")); ?>" class="formTextfield_Medium" tabindex="4" pattern="[^@]+@[^@]+\.[a-zA-Z]{2,6}" title="Please enter a value." required>
if ((strpos((",".ValidatedField("join","join").","), "," . "4" . ",") !== false || "4" == "")) {
if (!(false)) {
?><span class="serverInvalidState" id="email_ServerError">Please enter a value.</span><?php //WAFV_Conditional join.php join(4:)
</div>
</div>
</div>
</li>
<div class="fullColumnGroup"><label for="zip_code" class="sublabel" >Zip Code:<span class="requiredIndicator"> *</span></label>
<input id="zip_code" name="zip_code" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("join","zip_code"):"")); ?>" class="formTextfield_Medium" tabindex="5" pattern="(\d{5}([\-]\d{4})?)" title="Please enter a value." required>
if ((strpos((",".ValidatedField("join","join").","), "," . "5" . ",") !== false || "5" == "")) {
if (!(false)) {
?><span class="serverInvalidState" id="zip_code_ServerError">Please enter a value.</span><?php //WAFV_Conditional join.php join(5:)
</div>
</div>
</div>
</li>
</ul>
</fieldset>
</li>
<span class="buttonFieldGroup" >
<input type="submit" value="Join Moonshine Network" class="formButton Sidebar" id="Insert" name="Insert" />
</span>
</li>
</ul>
</form></div>
<div id="Insert_Sidebar_Default_ProgressMessageWrapper" class="blockUIOverlay" style="display:none;">
WADFP_SetProgressToForm('Insert_Sidebar_Default', 'Insert_Sidebar_Default_ProgressMessageWrapper', WADFP_Theme_Options['SmallSpin:Slate']);
</script>
<div id="Insert_Sidebar_Default_ProgressMessage" >
<p style="margin:10px; padding:5px;" ><img src="webassist/progress_bar/images/slate-smallspin.gif" alt="" title="" style="vertical-align:middle;" /> Please wait</p>
</div>
</div>
<script src="webassist/forms/wa_servervalidation.js" type="text/javascript"></script>
<script src="webassist/jq_validation/jquery.h5validate.js"></script>
<script>
var Insert_Sidebar_Default_Opts = {
focusout: true,
focusin: false,
change: false,
keyup: false,
popupClass: "Bloom",
pointedAt: "left",
fieldOffset: 10,
fieldMargin: 2,
position: "left",
direction: "left",
border: 1,
offset: 25,
closeText: "?",
percentWidth: 100,
orientation: "bottom"
function Insert_Sidebar_Default_Validate() {
$("#Insert_Sidebar_Default").h5Validate(Insert_Sidebar_Default_Opts);
$(document).ready(function () {
ConvertServerErrors(Insert_Sidebar_Default_Opts);
</script>
<p> </p><p> </p><p> </p>
<!-- end main --></div>
<!-- end #wrapper --></div>
<div class="footer100">
<div id="footer">
<?php require_once('includes/footer.php'); ?>
<!-- end #footer --></div>
<!-- end #footer100 --></div>
<!-- end #wrapper100 --></div>
<script src="http://ajax.googleapis.com/ajax/libs/jquery/1.8.2/jquery.min.js"></script>
<script src="js/superfish.js"></script>
<script type="text/javascript" src="js/myscript.js"></script>
</body>
</html>
