can't get rid of * on a non required field
Thread began 10/09/2014 8:25 pm by mousework50137 | Last modified 10/09/2014 10:56 pm by Jason Byrnes | 331 views | 1 replies |
mousework50137
If you go to http://patrickjefferson.com/new/email.php and take aloof at my email form you will see the telephone number has a * next to the fields label.
I have tried re-running the wizard and saying this field is not required bu the * still remains although the field does not require an entry.
How do I remove the * from the telephone filled?
Edit the code to remove the *. select it in design view and use the delete key
