font formatting on tables
Thread began 10/09/2014 3:52 pm by kg_nsa395746 | Last modified 10/11/2014 3:24 pm by kg_nsa395746 | 1168 views | 2 replies |
kg_nsa395746
I have a table set up on this web page. http://www.81st-218thdistrictcourt.org/dockets.php. The font formatting is specified in the CSS but when I add rows, Power CMS isn't reading the formatting correctly. Is there an issue with formatting in tables? See the last 3 rows. The only way I get the spacing to look correct is to click on Paragraph Formatting and select Normal. However, the size of the formatting is too small and the links in column 3 aren't bolded as coded in my <a> links.
look at the source code for one of the items that looks like you want it to and there are p tags around the link:
<p><a href="/files//WilsonCVADDS10-6.pdf" target="_blank">CV ADDS</a></p>
the links that dont have the formation, dont have p tags around them:
<a href="/files//KarnesIndictList.pdf" target="_blank">Indictment List</a>
looks like you need to add the p tags.
kg_nsa395746
Thanks Jason. I'll work on making the edits and let you know if I have other questions.
