How to query a table to display events on the current date (MySQLi Recordset)
Thread began 10/09/2014 4:19 am by Nathon Jones Web Design | Last modified 10/09/2014 9:20 am by Jason Byrnes | 798 views | 1 replies |
I have the following MySQLi recordset on my page...
$rsEVENTS = new WA_MySQLi_RS("rsEVENTS",$SMTmysqli,10);
$rsEVENTS->setQuery("SELECT * FROM SMTevents WHERE SMTevents.SMTeventdate >= Now()");
$rsEVENTS->execute();
...but this doesn't display events that are taking place on the current date. I tried this, which doesn't produce an error, but it doesn't resolve the issue:
$rsEVENTS->setQuery("SELECT * FROM SMTevents WHERE SMTevents.SMTeventdate >= (Now()-1)");
What should my SELECT statement be?
Thank you.
NJ
the NOW() function returns Date And Time:
2014-10-09 09:17:37
You should use CURDATE() instead which returns only the date:
SELECT * FROM SMTevents WHERE SMTevents.SMTeventdate >= CURDATE()
you may also need to reformat the date in the table if it contains the time portion to remove it:
SELECT * FROM SMTevents WHERE DATE_FORMAT(SMTevents.SMTeventdate, '%Y-%m-%d') >= CURDATE()
