PayPal Only please
Thread began 10/06/2014 7:25 am by Steve | Last modified 10/10/2014 12:31 pm by Jason Byrnes | 1619 views | 7 replies |
Steve
PayPal Only please
Hello,
I'm trying to only allow a PayPal purchase but not sure what to disable as the default checkout is still expecting a choice between Credit Cards OR PayPal.
The Checkout Wizard was set to just use PayPal in any instances where a choice was possible.
Commenting out the CC purchase option removes the trigger that changes the form and the button to the PayPal paths.
I can copy the form tag and button from source code that is displayed when PayPal is selected and then force my page to use those but what file is changing this? It's a Javascript include I expect.
Best methods to only have the Continue to PayPal button show?
You are choosing the PayPal payments pro option for the gateway. This enables 2 patpal services:
PayPal Express Checkout
PayPal Direct Payments (The credit card form)
To Use Express Checkout Only:
When running the checkout wizard, on the gateway tab, select the option "I Will Rely on my payment provider for a secure checkout"
Then select to use PayPal Express.
Steve
Thanks Jason... I guess since I got an error on the CC radial I did not get to see it also goes to PayPal.
Note: there seems to be an issue when applying a template and then theme to some of the pages generated from the Checkout Wizard (Framework Builder). You can see in the attached screen shot. It's happened to a few of the pages and while easy enough to manually sort, though you might be interested.
I Will log this as a bug in our system.
Steve
Jason,
Where do you want other Bugs posted to... For instance, updating a prior created MySQLi recordset and adding an Order By results in the OrderBy being put in the wrong area as shown in this attached screen shot. Repeated on multiple occasions and other Recordsets to confirm this was not a "one off"
Start a new thread for new bug reports please.
I am not able to reproduce this.
What is your OS? DW Version?
Do you have the latest version of MySQLi installed (1.0.2)?
On adding the order by clause, are you simple recordset view? advanced recordset view and editing the SQL code directly? the Query Builder? other?
Steve
Latest DW CC 2014
Latest MySQLi 1.0.2
Mac - latest OS
Advanced view not using Query builder nor entering it manually
Here's a set of screen shots that illustrates the problem:
Ok, i am able to reproduce with those steps, I have logged a bug in our system to have this corrected.
