Code Mistake
Thread began 10/06/2014 4:44 am by john70964 | Last modified 10/06/2014 11:38 am by Jason Byrnes | 266 views | 1 replies |
john70964
Code Mistake
Good Morning
I have an update form which seems to be working correctly.
However when I look at the code it seems that a field is incorrect.
1 The first field New or Used
Code:
<input id="NeworUsed" name="NeworUsed" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("generalupdate","NeworUsed"):"".$row_WADAboats["NeworUsed"]."")); ?>" class="formTextfield_Medium" tabindex="6">
2 The second field Category
Code:
<input name="NeworUsed" type="text" class="formTextfield_Large" id="NeworUsed" tabindex="6" value="<?php echo $row_WADAboats['Category1']; ?>">
3 This second field should initially show the category which it does, but should enable updating from the entry of the sample list below if needed.
Code:
<select name="Category" id="Category">
<option value="">See a Sample Category</option>
do {
<option value="<?php echo $row_rsCat['Category']?>"><?php echo $row_rsCat['Category']?></option>
} while ($row_rsCat = mysql_fetch_assoc($rsCat));
$rows = mysql_num_rows($rsCat);
if($rows > 0) {
mysql_data_seek($rsCat, 0);
$row_rsCat = mysql_fetch_assoc($rsCat);
</select>
Could you please suggest how to amend
I am attaching a zipped file
Many thanks
John
I dont follow, please provide more details on what the nature of the problem is.
