Creating product catalog
Thread began 10/05/2014 9:31 am by Daniel | Last modified 10/06/2014 11:49 am by Jason Byrnes | 2638 views | 3 replies |
Daniel
Creating product catalog (not using mysqli so failing)
Hi, I'm using DW4 and all the up to date supersuite extensions. I seem to be having trouble with databae connection as you can see by the error message below. When setting up the mysqli connection it never connects to the the table straight away and always need to click a second time to see my db's.. Can you helo me would please it seems that it's inserting old code.
I'm also using Wampserver (64 bits & PHP 5.5) 2.5
( ! ) Warning: mysql_select_db() expects parameter 2 to be resource, object given in C:\wamp\www\vials_test\products_detail.php on line 40
Call Stack
# Time Memory Function Location
1 0.0010 283808 {main}( ) ..\products_detail.php:0
2 0.0140 387056 mysql_select_db ( ) ..\products_detail.php:40
( ! ) Deprecated: mysql_real_escape_string(): The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead in C:\wamp\www\vials_test\products_detail.php on line 11
Call Stack
2 0.0160 387888 GetSQLValueString( ) ..\products_detail.php:41
3 0.0160 388096 mysql_real_escape_string ( ) ..\products_detail.php:11
( ! ) Warning: mysql_query() expects parameter 2 to be resource, object given in C:\wamp\www\vials_test\products_detail.php on line 42
Call Stack
2 0.0280 395672 mysql_query ( ) ..\products_detail.php:42
Data Assist has not been upgraded to work with MySQLi yet, we are currently working on that upgrade.
The conversion to MySQLi is a multi step process, the MySQLi server behaviors was the first step in the conversion, we have completed upgrading eCart 6 as well and are working on upgrading Design Extender and Data Bridge.
At this time, you will need to continue using standard MySQL connections when working in Data Bridge
Daniel
That's not ideal seen as I just purchased all the upgrades and a seminar. I hope it's going to be easy to migrate when you get it sorted.
I'm now getting this error:
( ! ) Deprecated: mysql_pconnect(): The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead in C:\wamp\www\vials_test\Connections\dbcon.php on line 9
Call Stack
1 0.0010 283352 {main}( ) ..\products_detail.php:0
2 0.0020 286200 require_once( 'C:\wamp\www\vials_test\Connections\dbcon.php' ) ..\products_detail.php:1
3 0.0020 286952 mysql_pconnect ( ) ..\dbcon.php:9
Will this show on the live site?
Thanks.
edit the php.ini file to turn off the depreciated error level.
http://php.net/manual/en/function.error-reporting.php
Whether it displays on the live site depends on the settings for displaying error in the live sites php.ini file.
