New error message when accessing object
When trying to access an existing e-cart object I am getting an error message. See attached. I did the usual, i.e., new work space, deleted .dat file.
Thanks as always.
Thanks as always.
Update... I checked another site with e cart and that is getting the same error message, so something DW wide not just one site.
Thanks.
BTW, this is new since WA outage, so that may be a clue. Thanks.
I resolved by reverting back to an earlier config folder.
attached is an updated copy of the Configuration/Shared/WebAssist/eCart/WA_RunCommand.js file that should fix the problem.
New error messages now. On is at line 1298 .... Shared/Controls/Sripts/WATtrigger.js missing
I Think i gave the wrong version of the WA_RunCommd file, try this one.
