waskype_Button.htm has configuation information that is invalid
Thread begun 10/03/2014 9:03 am by Daniel | Last modified 10/03/2014 9:27 am by Daniel | 1303 views | 4 replies |
Daniel
Hello I've just installed all the extension I purchased. I am however experiencing problems with several of the extensions on startup with Dreamweaver and they keep popping up every time I attempt to do anything. Can you please tell me how to solve the problem?
I've attached a screenshot of what I'm getting and the problem appears to be with PayPal and Skype as well as wagt_search.htm All of them tell me there is invalid information.
Dan Lewis
dan@wheretheshowsare.com
reset the workspace layout:
go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
Daniel
SUCCESS!!!
Great! that seems to have solved the problem.
I'm also interested in using the DataAssist extension and I've tried it. But what if I don't want to use your templates? My application is more custom than that. Where would I go to view more tutorials on that subject?
Using Data Bridge, there is an option to Use a Blank default design in the Data Assist wizard that does not contain any styling.
Daniel
Thank you!
I'll give that a try!
