MySQLi Log In User - How to detect if a user is logged in and how to hide certain content based on that (not auth levels)
Thread began 10/03/2014 7:31 am by Nathon Jones Web Design | Last modified 10/03/2014 9:53 am by Jason Byrnes | 1693 views | 5 replies |
I need to display either a "Sign in" button or a "Log Off" button depending on whether or not a user is logged in or not.
Can this be done considering I've built the whole thing in MySQLi?
Thank you
NJ
When you create the login behavior, the First setting on the general tab is the login name.
On login success a session variable is created using the login name as:
WA_AUTH_<login name>
so for example if you name the login "MyLogin", the session will be created as
WA_AUTH_MyLogin
you can create an if statement to check for that session variable and show logged in or not logged:
@session_start();
if(isset($_SESSION['WA_AUTH_MyLogin'])) {
Logged In
<?php } else { ?>
Not Logged In
<?php } ?>
Receiving a Parse error with that code:
Parse error: syntax error, unexpected 'if' (T_IF) in C:\inetpub\wwwroot\smt\smtadmin\navbar.php on line 27
Line 27 is:
if(isset($_SESSION['WA_AUTH_USER'])) {
Thank you.
NJ
sorry, forgot the semi colon at the end of the session_start line.
that line should be:
@session_start();
Thank you. That's fixed it.
you're welcome.
