How to add a break point in MySQLi results
Thread began 10/01/2014 10:13 am by Steve | Last modified 10/01/2014 11:08 am by Jason Byrnes | 1709 views | 5 replies |
Steve
Hello,
I have a basic recordset that polls for 9 records that meet a criteria. I'd then like to have the repeat region that displays these results only show them in groups of 3 after which I will put a break <br />
The result is three rows with 3 results in each row.
Basic Recordset polling for 9 records:
$Recordset1 = new WA_MySQLi_RS("Recordset1",$minBlog_i,9);
$Recordset1->setQuery("SELECT * FROM news WHERE news.newsType = ?");
$Recordset1->bindParam("i", "".$_GET['id'] ."", "36"); //target
$Recordset1->execute();
Repeat region that shows all records:
while(!$Recordset1->atEnd()) {
<a href="uploadedImg/<?php echo($Recordset1->getColumnVal("newsImage")); ?>"><img src="uploadedImg/thumb_<?php echo($Recordset1->getColumnVal("newsImage")); ?>" alt="<?php echo($Recordset1->getColumnVal("newsAlt")); ?>"/></a> <br />
$Recordset1->moveNext();
$Recordset1->moveFirst(); //return RS to first record
I expect this will take a looping event that counts the results and shows the 1st three, then inserts the <br /> then iterates another three until the count is complete?
add a count tothe repeat and add a <br/ > at 3
<?php $count = 1; ?>
$count++;
if($count == 4) {
echo("<br />");
$Count = 1;
Steve
That works great, but only puts a single break after three and then does not repeat for the second set :-(
http://rivieralaser.com/photos15.php?id=36
$count++;
if($count == 4) {
echo("End <br />");
$Count = 1;
sorry:
$Count = 1;
should be:
$count = 1;
Steve
Oh I see now... The $count increases with each iteration ($count++) and then there is the conditional statement that inserts the Break.
Next the $count resets so as to be able to loop again.
Awesome! Thanks Jason.
We could also use zero as the initial starting point:
<?php $count = 0; ?>
$count++;
if($count == 3) {
echo("End <br />");
$count = 0;
yes, you could use 0 as the starting point if you like
