Can't Get Past Serial Number
I'm trying to install PowerCMS Builder but it will not advance past Step 2 Serial Number. No errors it just returns the page with the serial number blank each time. Any ideas?
Site is at: http://www.cavalierresidences.com
See details in private section.
Something in your sites .htaccess file is causing a conflict. if I rename it from .htaccess to htaccess_old, then the serial page will advance to the database page.
I added a new .htaccess file to the install_cms directory containing:
RewriteEngine Off
to fix the problem and finish the installation.
