Rotating news section that I did through premier support
Thread began 9/29/2014 10:25 am by russb335115 | Last modified 9/30/2014 1:36 pm by Jason Byrnes | 1707 views | 5 replies |
russb335115
I have a rotating news section that we developed through premier support. In it there is a blue image on the top right that is supposed to show the open news instead of rotating it (its a drop down effect). It was working but now its not, it recognizes the link that is attached to the rotating header instead.
Can you tell me what happened? Here is the address where you can see it.
http://s537074315.onlinehome.us//gcs-2014/index.php
Seams to be working correctly for me, try clearing the browsers cache.
russb335115
Thanks Jason, I was able to get it working.
My only issue now is that the link isn't working correctly. If you click on the title of the rotating text it should go to a results page. It does do that but it only gives the results for one of the titles. Doesn't matter which one you click it give the same results.
I not the link isn't set up right but not sure how to correct it. Tried to match the links on the main news results page but it didn't work.
Can you help?
the links should contain a URL variable with the ID, for example:
?ID=1
looks like your link s in the header are missing the URL variable, for example:
<a href="gcs-news-details.php?ID=<?php echo $row_recordsetName['IDColumn']; ?>"><h2>This is the header</h2></a>
where recordsetName is the name of the recordset used to populate the news title and IDColumn is the name of the id column returned by the recordset.
russb335115
That worked!
Thanks Jason,
you're welcome.
