Higher versions of PHP
Thread began 9/29/2014 9:02 am by codamedia | Last modified 9/29/2014 9:07 am by Jason Byrnes | 327 views | 1 replies |
codamedia
Most (if not all) Web Assist extensions list the requirements as PHP 5.2 - which is quite old. This is not noted as a "minimum requirement", so I am wondering if the extensions are tested with the newer versions of PHP. If so - what is the latest version you are testing with?
The web assist extensions should work fine with newer PHP versions.
