MySQLi record count using LIMIT keyword
Thread began 9/27/2014 12:29 pm by CraigR | Last modified 9/30/2014 1:50 pm by Jason Byrnes | 1493 views | 17 replies |
CraigRBeta Tester
MySQLi wrong record count when using LIMIT keyword
I have a mySQLi recrdset from a table with 13 rows, but I added a LIMIT keyword so only the first 6 rows are returned,
This works, but if I add the server behavior 'MySQLi Display Total Records' , the value returned is 13, not 6
CraigRBeta Tester
PM
When using a repeat region, the limit is set to the number of records you select to return.
what this means is:
by default when you create a recordset, the limit is set to 1.
This gets changed when you apply the repeat region. you say that when you applied the repeat region, the limit was set to 0, this would happen if you selected to return all rows in the repeat region behavior.
so, create the basic recordset with out the limit applied, add the column binding to your page with the repeat region around it, in the repeat region, set the number of records to return to 4. this will update the limit in the recordset to 4.
to show the current starting record number and the ending record number, use the WebAssist -> MySQLi -> Display Record Count -> MySQLI Display Starting Record Number and MySQLI Display Ending Record Number behaviors
to page through the recordset use the MySQLi recordset paging controls
CraigRBeta Tester
Ok, I get it.
I can calculate the number of rows returned by subtracting the ->StartRow from the ->LastRow
The total rows calculation does not take into account the LIMIT keyword at all
With the offset, how do I return, (for example) records 5-8 from my table with MYSQLi ?
using the MySQLI Display Starting Record Number and MySQLI Display Ending Record Number behaviors
CraigRBeta Tester
sorry, not getting it.
my sql statement is as follows...
$Recordset1 = new WA_MySQLi_RS("Recordset1",$PowerCMSConnection_i,4);
$Recordset1->setQuery("SELECT tbltestimonials.* FROM tbltestimonials");
$Recordset1->execute();
so my limit is 4
Can you show me how to show rows 5-8 in a repeat region, is the offset done in the sql statement or in the repeat ?
the offset is done using the paging controls to add the show next page link
CraigRBeta Tester
so how do i show rows 5-8 in a repeat region, on a single page ?
add the paging controls to your page so that you can click the next link, after clicking the next link it will show records 5-8. next again will show 9-12 etc.
