dynamically related files could not be resolved because of an internal server error
Thread began 9/20/2014 5:26 am by anthony.tierney414096 | Last modified 9/25/2014 8:12 pm by Jason Byrnes | 1271 views | 1 replies |
I’m trying to install the file upload server behaviour from Data Bridge. After I include the behaviour I keep getting this message; dynamically related files could not be resolved because of an internal server error! I’ve uninstalled Data Bridge and re installed it several times now, but I still get the same problem. If upload the files to the server the page just goes blank. If I remove the server behaviour the file loads ok. When I had the previous Digital File Pro before upgrading to Data Bridge it all worked fine.
Just had a look and I think the problem could be with the helper file. it say There is a syntax error on line 74.
Im running Windows 7 64bit OS and Dreamweaver CS6 with all Updates.
here is an updated copy of the webassist/file_manipulation/helperphp.php that should fix the problem.
helperphp.php.zip
